05-02-2012, 09:37 PM | #1 |
right front halo
ok so tonite was the firstt time i took my car out at night in awhile, i noticed that the right from halo is working but the headlight it self is not working...
what could this be? a disconnected plug? could the bulb have burnt out? do they selll replacements for those or do i have to buy the whole unit? thanks jeff
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-02-2012, 09:42 PM | #2 |
knows 2 facts about ducks
Yes they sell replacement bulbs. But it should be covered under your bumper to bumper warranty
05-02-2012, 10:32 PM | #3 |
ok thanks...i have to take my bumper off first n check if its connected..i might of disconnected it,,but the halo works..are they seperate connects or the same connection?
05-02-2012, 10:35 PM | #4 |
Drives: Chevrolet Camaro 2011 RS 1LT Join Date: Apr 2012
05-02-2012, 10:38 PM | #5 |
You don't need to take the bumper off. The harness plugs are on the back side of the headlight. You can access it from the engine bay
05-02-2012, 11:09 PM | #6 | |
Drives: '10 Camaro SS Join Date: Feb 2012
I just changed my bulb today! The Halo and headlight are two separate things. The halo works using an LED and is a lot more complicated, the projection light is just an HID BULB that fits in a harness and has a plug/socket wire. I doubt that it unplugged in your case, it's more likely that they burnt.
If one of the bulb burned, look to see if the other one is changing color or flickering so you can change them both. You might want to take the working bulb off and try it on the other one to see if its just the bulb thats the problem. Here's how: Quote:
IMPORTANT: 1. Do not touch the HID bulbs at all cost, oils and residue from your hands could make the bulb burn out later. 2. Make sure the bulbs twists correctly in place or they might melt something inside from the heat/touching something. I unfortunately had 40k miles on my car so I wasn't covered by warranty, the GM HID bulbs are pretty expensive (~$150 each, just the bulb)
05-03-2012, 06:05 AM | #7 |
Ill bring it in..but if they dont cover it do you know the part number for the bulb?
Sent from my SCH-I510 using Tapatalk 2
05-03-2012, 08:28 AM | #8 |
If i can get a part number for this i might be able to.get it for cheaper
05-03-2012, 11:36 AM | #9 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
i havr a brand new bulb pm me
Email: rdurso1@yahoo.com |
05-03-2012, 12:09 PM | #10 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
05-03-2012, 01:11 PM | #11 |
Thanks..im btining it to the dealer today..if they dont cover it ill hit u up..u assume they will cover it
05-03-2012, 01:12 PM | #12 |
Tha.ks! Should the bulb be under warranty?
05-03-2012, 01:31 PM | #13 |
I dont know that one.
05-03-2012, 06:17 PM | #14 |
Well I brought my car in for the bulb as well as my heated seat which stopped working, and my passenger side speaker, they r replacing them all under warranty, thank goodness, he said that bulb is 300 dollars, that's crazy
Thread Tools | |
