03-11-2016, 11:19 PM | #1 |
Drives: 2015 Camaro 2LS Join Date: Jun 2015
MRT V2 Exhaust Issues
So I got my MRT V2 Exhaust installed today, but I have 3 questions for you guys(Sorry I'm a rookie for mod).
1. Seems that the exhaust is not long enough to stick out(or the muffler shop cut the pipe short), and the plastic above the tip gets extremely hot after driving. Will this be an issue? Will the plastic material become out of shape? 2. The drone at 1800~2500rpm is like crazy, muffler shop says it will get better several days later, is that true? 3. The exhaust get misaligned after driving, muffler shop says this is normal, and I need to re-align one week later, is that true? Thank you for your answers! |
03-11-2016, 11:29 PM | #2 |
El Duderino
No reason to be too short, unless they screwed up. If it dosent stick out of the diffuser by at least an 3/4 inch, take it back and make them fix it. Might find your rear end on fire while cruising down the interstate.
The drone will improve after break-in, but will still be prominent in that rpm range. A good way to reduce that would be with a MagnaFlow X pipe in place of your OEM "H" pipe. A CAI also helps with overall sound enjoyment. Was it welded? It shouldn't be moving around if it was welded. Sounds like you need to take it back and have them install it correctly.
I bowl. Drive around. The occasional acid flashback.
03-11-2016, 11:33 PM | #3 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Not sure about #1, but question their answers to #2 & #3. Have had several exhaust systems installed on vehicles over the years. Have never noticed any significant change in sound/drone after a 'break in period.' Also, have never had to 'realign' them, sounds like something wasn't tightened/secured properly.
03-11-2016, 11:36 PM | #4 | |
03-11-2016, 11:39 PM | #5 | |
03-11-2016, 11:44 PM | #6 | |
Also, if it's welded do I need to cut the pipe again if I want to install the magflow x-pipe? THanks! |
03-12-2016, 01:12 AM | #7 | |
El Duderino
Sounds like they value their public image, so point them to this forum as an opportunity to do (or show) quality work.
03-12-2016, 01:14 AM | #8 |
El Duderino
I would hold off on the X pipe for a month or so. Especially if you have a good CAI. JMHO
03-12-2016, 01:20 AM | #9 | |
03-12-2016, 01:30 AM | #10 |
El Duderino
If they hesitate, you might point out that if the exhaust doesn't clear the diffuser, then it could seep into the trunk, and from there, into the passenger compartment. Last thing you want is an undetectable, deadly gas in the cabin!
03-12-2016, 01:34 AM | #11 |
Good point!
03-12-2016, 01:36 AM | #12 | |
El Duderino
Actually, I would think they will take care of you given the chance. I mean really, most small business value their reputation. If not, you have resources.
03-12-2016, 02:41 AM | #13 |
Drives: 2010 2LT/RS Black/IOM Join Date: Feb 2011
They either cut it too short or pushed the new pipes too much. Yes its natural to need to fix the "centering." What I mean is, one pipe did slip a little and it needed to go back up into place. I watched him do it with an impact wrench both times on the lift. Just the force of the wrench made it tricky to get right. I kinda thought, maybe tighten by hand? I don't mind the sound. Thats why I got them.
ZL1 Factory Reproduction Wheels, Airaid CAI, MRT V 2.0 Axle Back Installed by PIE Customs, Painted IOM Rally Stripes, Bowties by Danny Taylor Louisville KY, IOM Engine Cover and Fusebox Cover by River City Creations and Lighting San Antonio TX.
03-12-2016, 02:54 AM | #14 |
Also, got a picture? Heres mine.
