08-25-2018, 02:36 PM | #1 |
Drives: 2012 Camaro 2SS Ls3 Cammed/Blown Join Date: Feb 2016
650 to the wheels broke an axle
Broke an axle last night dropped the clutch spun shifted to second and boom it broke I’m surprised the stock axles lasted as long as they did. My question is. Is there any chance that the rear end was damaged from this? I jacked the car up and the wheel with a good axle spins freely so I think I’m okay.
Thanks for the help in advance and does anyone have some aftermarket axles for a good deal? |
08-26-2018, 09:17 AM | #2 |
old school chevy rodder
A good drain and refill/inspection of the rear gears would be in order with the anti-slip additive if stock gear set and such..... Also a set of BMR trailing arms and toes also with their poly bushings and stiffness to absorb things related to wheel hop that usually is the cause of thrashed axles..... Its the catching of traction from lack of traction over and over that breaks the stock axles usually. I would recommend upgrading to zl1 axles if not doing more for the stock set up suspension like BMR toes trailing arms and say eventually a LPW pumpkin cover...to stiffen the pumpkin even....and learn to feather it a little more the stock axles are rated more into 450 rwhp area..... And avoid a hard launch with sticky tires...like stay stock tires and more in the 3500 range unless you want to burn rubber and then you have to limit wheel hop....
08-26-2018, 02:57 PM | #3 | |
I actually do have bmr trailing arms and I’m planing on eventually getting the toe rods LCA’s and some bushings and I’m going to be upgrading the axles this time to DSS 1000Hp so that I don’t have to worry about that any more. Thanks for the response. |
08-26-2018, 02:59 PM | #4 |
I’m gonna be installing the new axles myself anyone have some tips?
08-26-2018, 03:21 PM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
With aftermarket axles, be very careful in handling them out of the car. Keep them straight. Many aftermarket ones if they flex too far, the joints pop apart. Then you'll me messing around looking for new band clamps and half a day trying to figure out how they go back together. Been there done that. Went to install a set once and they were both bound up. Both axles had cv joints that had popped apart in shipping.
08-26-2018, 04:17 PM | #6 |
Does anyone know if stock axle nuts will fit on the DSS axles?
08-26-2018, 11:50 PM | #7 |
Boosted Moderator
If I remember correctly, they come with new axle nuts...
My memory isn’t the best but I believe that’s the case... call them and ask... if nothing else they will probably toss a pair in... I’m on DSS axle set number 4... (I have three useable sets for race events) never an issue... 1400 hp rated axles... I’ll just say I abuse them... severely... love em...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
08-27-2018, 12:05 AM | #8 |
'It's an experiment'
DSS comes with their own reusable axle nuts...
Torqued to 199 ft lbs last time I did mine ;o) -Don
747 RWHP 794 RWTQ
08-27-2018, 02:24 AM | #9 |
08-27-2018, 06:19 PM | #10 |
Here’s another question the axle broke at the shaft that goes into the diff is it going to be difficult to get it out?
08-27-2018, 09:41 PM | #11 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
Nope the inner part of the cv is still attached which is what you pry against to get the shaft out of the diff. Probably easier for you get out since it’s in 2 pcs.
08-28-2018, 07:37 AM | #12 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
10-02-2018, 11:23 PM | #13 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
I am done with the 1400 hp dss half shafts and driveshafts. Beside sending miss matched ones. Stock ones seem stronger and I am looking at gforce ones.
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
