08-31-2018, 05:53 AM | #1 |
Drives: 2010 SS Camaro Join Date: Jul 2018
Drivers Door Squeak's when it latches closed?
So my Drivers Door Squeak's when it latches closed. Has anyone else experienced this? I have adjusted the door and the Striker/latch. Its smooth as butter now and closes very easily! Its also lined up as close to perfectly as possible. Still when You are sitting in it and you close the door. As it latches closed you get a little squeak... I have also lightly greased the Latching mechanism itself and that did not help. I dont see where it might be rubbing anywhere either? DO any Of you have an Idea what could be going on? Thanks In advance for any help!
Cory C
Husband and Father
08-31-2018, 06:09 AM | #2 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
Try putting a little bit of penetrating oil on the hinges and see if that helps
08-31-2018, 06:43 AM | #3 | |
that's a good Idea, I will do that
Husband and Father
09-02-2018, 05:49 AM | #4 |
well that did not seem to help. Any other ideas =)
Husband and Father
