Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Audio / Visual / Electronics/ Gauges / Nav
Old 02-07-2017, 02:22 PM   #85
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
Ordered mine today! Awesome deal.
SSmokinSS is offline   Reply With Quote
Old 02-26-2017, 04:35 PM   #86
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
Exclamation
RDP Store is Proud to Offer Great Savings on Aeroforce Gauges for your Camaro.
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units. Gauges come with a black bezel with polished silver center ring with a black face as shown on right. An extra white face is also included and can easily be swapped since the bezel screws on/off. Optional black, polished silver, and brushed silver bezel along with various other face options can be purchased separately from the accessories page.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
Has high intensity warning lights that can be set using a 1 or 2 parameter algorithm. P1, P1 or P2, P1 and P2. For example, trigger the lights when rpm exceeds 6000 rpm, or when trans temp exceeds 230 F and coolant exceeds 210 F, or when air fuel ratio is above 12.5 and throttle is above 75%. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display (as pictured below). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the other parameters obtained on the vehicle's bus.
The gauge has bi-directional controls allowing for manual control of the low and high speed fans, CASE relearn and ECU reset on GM vehicles, and on most Chrysler vehicles the transmission controller can be reset and Electronic Stability Program can also be completely turned off to improve track performance.
New optional relay output module allows you to control a 12v relay based on values of OBD2 or analog input data.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished through a simple menu selection. This function is not available on the ISO based (older imports) due to slower bus speeds.
Installation in most cases is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally plug-and-play! Some vehicles such as those requiring the ISOi version (older imports) require switched 12v power. The rear connector of the gauge has a provision for this so installation is still a snap!
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously. The second gauge of a dual set in most cases is simply another single gauge programmed to working in tandem. The exception is the SR dual set in which case the second gauge will show a smaller subset of parameters that the main gauge. This is due to limitations of the Chrysler PCM. Check the list of parameters and features for more details. This second gauge also will not have a performance timer.
Warranty
Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from the date of purchase.
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display. A sample list is below...
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
For Super Specials Pm us here or give us a call on 440 358 5500 or 440 251 8571
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power ACT Aeroforce Kooks Husky AWE Gforce GForce SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC FIC
dynosteve is offline   Reply With Quote
Old 03-15-2017, 11:18 AM   #87
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
PM me price shipped to 92057. Thanks
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 04-06-2017, 08:35 PM   #88
jesuslperez66
Drives: 2012 Chevy Camaro 2SS
Can you send me a price for a 2SS 2012 to 89128 tanks
Sent from my iPad using Tapatalk
jesuslperez66 is offline   Reply With Quote
Old 04-18-2017, 11:26 AM   #89
BallerMaro13
Drives: 2013 ZL1 M6 Black/Black
Currently shopping these. Can you please price me the dual gauge setup for a 2013 ZL1, black face with ZL1 logo to 28226? Thank you!
BallerMaro13 is offline   Reply With Quote
Old 04-30-2017, 09:26 PM   #90
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M ECS 1500
Can you please send quote on shipping to 23456 , dual gauge setup red lights, i have a Supercharged SS with 3bar map
Santos is offline   Reply With Quote
Old 05-09-2017, 10:11 AM   #91
Dragonman
Dragonman's Avatar
Drives: 2015 1LT OBE
Will you be at Camarofest 7? (I don't recall reading whether you would be or not. Will go look again after I catch up on the rest of the forums here.) If so would you mind bringing a black a-pillar dual gauge pod? The one on your site shows it's for 2010-2013 and I'm wondering if I could take a look at it or if you have one for 2015 models. I'm not certain of the finish on these items and wonder how it will look in my car. Pretty sure I've a wish list on your site as well and the Aero Force Dual gauge setup, which I'm unable to find on the site now, was in it. Hmmm. Now I'm going to have to remember my log in to check the wish list out.
Thanks.
_______-2015 1LT JUSTICE----------------------------------1997 B12-___________
Dragonman is offline   Reply With Quote
Old 08-08-2017, 03:11 PM   #92
dynosteve
dynosteve's Avatar
August Specials Free Shipping and Killer Pricing, See something you want why not make a Offer?
Shop 440 358 5500
Cell 440 251 8571
Old 08-22-2017, 10:06 AM   #93
dynosteve
dynosteve's Avatar
Shop 440 358 5500
Cell 440 251 8571
Old 10-02-2017, 02:49 PM   #94
dynosteve
dynosteve's Avatar
You can shop online with confidence at RDP Store with our extremely secure check out and can enjoy manufacturers warranty when purchased through RDP Store. If you have any questions you can reach out to us at anytime 7 days a week through phone (440)358-5500 or email sales@rdpstore.com or PM us here on the forum. Dont see the product you want let us know and we will find it for you and add it to our online store and give you an additional "finders fee" discount.
Shop 440 358 5500
Cell 440 251 8571
Old 10-14-2017, 05:21 PM   #95
dynosteve
dynosteve's Avatar
specials still running
Shop 440 358 5500
Cell 440 251 8571
Old 11-14-2017, 06:00 PM   #96
dynosteve
dynosteve's Avatar
End of Year Deals and Specials Currently Underway with Free Shipping to the lower 48 states and cost price shipping any where else in the world
Shop 440 358 5500
Cell 440 251 8571
Old 11-14-2017, 06:37 PM   #97
NoContact
"Elvira"
NoContact's Avatar
Drives: 2010 2SS Black with grey stripes
I've been wanting some gauges for my car. May have to give you guys a call.
NoContact is offline   Reply With Quote
Old 11-18-2017, 02:34 PM   #98
XROD
Drives: 2010 CAMARO SS
2010 Camaro SS Aeroforce Gauge and Pod
Whats the year end deal$ on these?
XROD is offline   Reply With Quote
aeroforce gauages rdp
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
