Emblempros
Old 05-18-2020, 10:29 AM   #1
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Whipple guys! Dropping pulley size to raise the boost, but is a belt change needed?
I've been running a 3.75" pulley for a while now with the stock belt, but reports vary on when you need a different belt to prevent slapping/shredding them. I'm about to drop to a 3.5" pulley and looking for real world experience on what belt to use, and wether to order the pulley from Whipple or go with a Griptec (or other maybe?). The car is 6 rib with no belt slip and will likely not go to 8/10 rib in the future.
2011 Camaro 1SS
Whipple Supercharged street monster
Aries240SS is offline   Reply With Quote
Old 05-18-2020, 12:34 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
For a 3.5" pulley, definitely go with a Grip-Tec, even with that, you may still get some belt slip. Yes, you will also definitely need a shorter belt. I'm running a 3.625" pulley on mine right now. I'll look at the belt number when I get home and post it here for you.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 05-18-2020, 12:37 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I run a 3.5" pulley...I'll see if I can get you a # off the belt.
EDIT....sorry, I don't see a pn on it anywhere...but it is a 6rib (with no issues).
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 05-18-2020, 01:52 PM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Whipple has a good belt wrap and really strong tensioner i'm still on stock belt at 3.75". You'll have to get a shorter belt but i don't think you'll have a slip issue as long as your boost is reasonable
Whipple 2.9 CAI ID1050x injectors JMS BAP JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering long tubes 2.5 cat back borla atak ZL1 pump JRE flow control module JRE scoop 1.5" lowering springs BMR trailing arms and toe links 704WHP 603WTQ
Greenhornet2 is offline   Reply With Quote
Old 05-22-2020, 09:19 AM   #5
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
If you drop from a 3.75 to a 3.5 a new belt might not be required. In stead of having charts on charts on charts to figure out every cars correct belt length for every pulley combo on the planet, we find its easier to just do a little research. First find out your current belt size and then look up on Gates website to see the next size smaller. If it's a big jump, wait till you decide to drop down again. If its just a bit smaller go ahead and give it a shot. Droping .25" on a pulley would not require a much smaller belt at all. Especially if the current belt was difficult to put on.
We carry & install all the hottest brands for your 5th/6gen Camaro. Get awesome deals & install rates! Call or Pm us for your CAMARO5/CAMARO6 discount. 224-63-JUICE or INFO@JUICEDMOTORSPORTS.COM ST CHARLES IL
Juiced1 is online now   Reply With Quote
Old 05-27-2020, 04:57 PM   #6
Aries240SS
Good advice. Thanks!
The current belt was rather easy to put on, so I'll check the Gates page and see if there's something just a tiny bit smaller to use.
Now if I could just find someone with the griptec pulley's in stock...
2011 Camaro 1SS
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
