#Camaro6
BeckyD @ James Martin Chevy
Old 06-01-2020, 01:40 PM   #1
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
PTM menu
Little help here please
So I put the car in track mode and tap the traction button twice and go in competitive mode the PTM menu will quickly pop up on the DIC and then disappear. Am i doing something wrong or is mine broken? what is the trick to getting it to stay on in a M6 so i can select from the different modes?
Thanks
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 06-01-2020, 02:08 PM   #2
PROMETHEUS
PROMETHEUS's Avatar
Drives: 2019 ZL-1, Shadow Gray, Sold
Yea, it is a PITA. I still haven't figured out the trick. I have to play with it all the time to get it to stay on. I have gone at different speeds with the two clicks and still have difficulty getting it to stay on. I am sure someone will chime in with the magic elixir!
PROMETHEUS is offline   Reply With Quote
Old 06-01-2020, 02:12 PM   #3
puppykat33
puppykat33's Avatar
ok at least its not just me. i keep double clicking the traction control button turning it from off and back into competitive mode but have only got it to stay on maybe twice. so i guess we both are at a loss for the right way to do it.lol
Old 06-01-2020, 02:28 PM   #4
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Same here. Sometimes it stays on and sometimes it doesn’t.
CW3SF is offline   Reply With Quote
Old 06-01-2020, 02:30 PM   #5
puppykat33
puppykat33's Avatar
Thanks Chief
guess we need to ask AL. lol
Old 06-01-2020, 04:01 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Don't push the traction control button anymore after you've entered PTM mode. Use the "mode" button up or down and the PTM mode will instantly appear and you can see what PTM mode you're in and what mode you go to. If you see both the Stabilitrak light and the traction control light illuminated on the dash you know you are in PTM mode.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-01-2020, 04:08 PM   #7
puppykat33
puppykat33's Avatar
Thanks Bud
Old 06-01-2020, 04:27 PM   #8
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Comp. Mode is available in Sport Mode. The PTM modes are accessed via Track Mode
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
Old 06-01-2020, 04:46 PM   #9
waterman
waterman's Avatar
Drives: Grandad's C2 L89
https://www.camaro6.com/forums/showthread.php?t=496996
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 06-01-2020, 04:56 PM   #10
puppykat33
puppykat33's Avatar
Originally Posted by waterman View Post
Yea i have read that but it still confuses the crap out of me. Im still having a problem getting the PTM menu to stay open so i can select a mode. wet,dry,sport1&2,race...
Old 06-01-2020, 06:01 PM   #11
Stephen12ZL1
Drives: '21 ZLE A10
the reason why the PTM mode does not remain on the screen is because the screen provides other information for track use and you don't need to be staring at what mode you're in the entire time on track. A quick press of the mode button and the screen pops up overriding any other information present for a split second.
Old 06-01-2020, 07:26 PM   #12
CW3SF
CW3SF's Avatar
Sounds like people aren’t understanding the issue here. The issue he has (and the issue I had) is that we select Track Mode, then press Traction Control Twice. That SHOULD bring up the PTM menu.
SOMETIMES IT DOESNT. It only flashes to the PTM screen for a split second and it disappears. No one is trying to drive around the track with it on. We are simply trying to get into the menu in order to select which mode we want (Wet Dry Sport 1, etc)
We know how it is supposed to work. It isn’t working correctly. Hope this helps LOL
Old 06-01-2020, 07:28 PM   #13
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
Chevy made something easy very hard. All we needed was 2 memory buttons with pre selected settings. That’s what not happened.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 06-01-2020, 08:10 PM   #14
crab
crab's Avatar
Drives: 2019 1LE
I've noticed don't double click too fast or it may not go into ptm.
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
crab is offline   Reply With Quote
