01-03-2019, 05:34 PM | #1 |
Drives: 2018 Chevrolet Camaro 2SS 1LE Join Date: Jul 2017
SS 1LE Rear Spoiler
Im curious if there are any aftermarket Rear Spoilers that can replace the 1LE Rear Spoiler and match up to the same mounting holes?
01-03-2019, 07:46 PM | #2 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
the 1LE rear spoiler is held down by double sided tape not sure if there are holes. You could go with the ZL1/1LE spoiler
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
01-03-2019, 08:16 PM | #3 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
01-03-2019, 09:35 PM | #4 | |
https://www.ebay.com/itm/1LE-Extende...L/323496840212 |
01-03-2019, 09:56 PM | #5 |
01-03-2019, 09:56 PM | #6 |
01-03-2019, 10:30 PM | #7 |
Ryan
01-04-2019, 12:35 PM | #8 |
Drives: 2018 ss 1le Join Date: Jan 2019
01-04-2019, 02:30 PM | #9 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
There are 9 holes in the SS 1LE decklid for the OE spoiler: 3 for threaded studs on the LH side, 3 slots for clips in the middle, and 3 more threaded stud holes on the RH side. Only 2 of the existing 9 holes will line up (the middle threaded stud hole on each side). The others would need to be sealed somehow and then you'd have 4 more holes to punch out. Here's a crappy drawing that gives a rough representation of how it's laid out. Black are existing holes in the SS 1LE decklid and green are the ZL1 1LE mounting locations.
2017 SS 1LE.
01-04-2019, 05:05 PM | #10 |
Since the holes in the 1LE trunk are different than the SS & ZL1 trunk, you need a donor trunk or have to drill extra holes and fill/cover some others. The donor or new trunk should be from a 2017 (or later) SS or ZL1 since they have the extra reinforcement same as the ZLE trunk if you want to use the wing. I have also heard the trunk support rods are different to support the extra weight of the big wing.
01-04-2019, 05:07 PM | #11 | |
01-04-2019, 08:21 PM | #12 |
01-04-2019, 10:20 PM | #13 |
This one looks like it's actually made for the 1LE
https://extremeonlinestore.com/colle...12590246625381 |
