Old 04-09-2020, 09:09 AM   #1
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
Traction control check light
Hi guys
Has been a long while since I posted on this forum
Question
I have a 2014 bought it new never had a problem besides little things that everyone is aware of
Yesterday the battery was dead after not driving it much for a little while
When I restarted it show a code on the dash STABILITY control check
If anyone had this happen and or know what’s all about please guid me on how to correct it
Thanks in advance
Ray
Jackass is offline   Reply With Quote
Old 04-09-2020, 09:36 AM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Bad battery? Clear the code and drive it around and see if it goes away.
2012 Camaro 2SS/RS - Katech ported TB, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, K&N cai, Roto fab washer relocation, DynoSteve tune, DLR harness, 35% tint, footwell led kit, luxe tinted markers
Awaiting installation - GPI Ported/rod modded manifold, apex scoop
Bigdumogre is offline   Reply With Quote
Old 04-09-2020, 09:38 AM   #3
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Check voltage of battery first: low voltage can throw all kinds of codes. New Battery should be 13.7-14.2 volts.
JB'sZL1 is online now   Reply With Quote
Old 04-09-2020, 12:09 PM   #4
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Originally Posted by Jackass View Post
Hi guys
Question
If anyone had this happen and or know whatís all about please guid me on how to correct it
Thanks in advance
Ray
Buy a trickle charger, started mine up and drove around the block yesterday. 1st start since last Oct, still the original battery manufactured in 2012.
ZMEnow is offline   Reply With Quote
Old 04-09-2020, 12:33 PM   #5
JB'sZL1
That may work, but could be an expensive lesson ZME. Straining the starter and other components with low voltage will wear them prematurely. I just replaced my oem '13 battery with an 800 cca (75 more than oem) for $100.00. Cheap insurance, and jut what you got to do with your toys: maintain them. 4-5 years on a battery, especially at $100, is nuttin'.
Old 04-09-2020, 05:25 PM   #6
ZMEnow
Check the battery every year it’s perfect. A maintained battery will last a very long time, the key word is maintained. Maintaining the acid level/ changing it, and using a top notch charger that exercises the battery. For a battery that’s only getting used 6 months a year of the warmest months, and less than 1800 miles a year, it will be just fine.
Old 04-09-2020, 06:12 PM   #7
12oclockshadow
Drives: 2012 ZL1 M6
Where did you get battery for $100? All I see are way more than that lol
604 RWHP / 604 RWTQ @ 15 PSI
Speed Engineering 1 7/8 Headers no cats, LPE 2.38 upper pulley kit, Roto-Fab CAI, FIC 1000 injectors, MSD plug wires w/Kevlar heat sleeves, Brick Mod, 160 degree thermostat, Custom Tune by Mike Gforce Motorsports, Phastek Blue map LED and LED footwell lighting, VLEDS DRLs and FOGs.
12oclockshadow is offline   Reply With Quote
Old 04-09-2020, 06:15 PM   #8
JB'sZL1
Where are you looking? lol
Old 04-09-2020, 08:17 PM   #9
12oclockshadow
Drives: 2012 ZL1 M6
Local auto parts. Im still on stock battery to. Starting to slow little on start ups
Old 04-10-2020, 05:50 AM   #10
JB'sZL1
Advance Auto with code (I had 30%) will get you right near $100.00.
Old 04-10-2020, 12:05 PM   #11
Jackass
Jackass's Avatar
Thanks everyone for the answers and different way to get it back to sniff
Late yesterday I went for a little drive and when returned home I turned the car off for a few minutes (~ 15) and restarts and just like that it was all clear !!! Just like that , just as added info this is my second battery , itís about 2 years old , I think that because I donít drive it much , and in the last 3 weeks Iíve just about pull it from the garage early AM. and bring it back in late in the days the battery went down . But itís all good again and just needs more miles I guess
Thanks everyone for the input , stay safe out there
Thanks again
Old 04-10-2020, 01:52 PM   #12
12oclockshadow
Drives: 2012 ZL1 M6
Ill chk back. Many thanks man!
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
