10-12-2018, 10:22 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
What Size HX plumbing? Stock? 3/4”? 1”?
I am upgrading my entire Supercharger/cooling system with the following products and curious to know everyone’s thoughts on the appropriate plumbing size for my setup... I am leaning toward 1” throughout.
-Prospeed Heat exchanger -EMP WP29 HX pump -RotoFab Res Thanks in advance |
10-12-2018, 11:08 PM | #2 |
Drives: 2010 Camaro SS Join Date: Jan 2015
Here's my new setup
I'm running 3/4" |
10-12-2018, 11:51 PM | #3 |
That looks clean! Do you run ice in that or just coolant?
10-13-2018, 02:09 PM | #4 |
10-14-2018, 02:07 PM | #5 |
I chose 3/4” over 5/8” which is what I was considering. I know the flow increase for 1/4” of hose is pretty substantial but I would think 1” has a greater capacity than most pumps but I don’t know that for sure. Looking at the numbers 3/4” looks more than adequate. Don’t know the difference in price so that would probably determine the chose at that point.
10-14-2018, 06:11 PM | #6 | |
I’m leaning towards the 1” because the pump I got pushes excessively more fluid then even my Magnuson provided pump and night and day compared to ZL1 stock equipment... |
10-14-2018, 07:21 PM | #7 |
What pump are you running that requires 1"?
I'm running a Rule 2000 in tank and the stock Bosch after the HX pushing back to the tank. Works great |
10-14-2018, 10:25 PM | #8 |
That setup with the Rule pump is fairly popular. The flow of volume is inversely related to pressure, so if you have a pump that doesn’t flow well or won’t pump under greater pressure, I would use the 1” . Otherwise it probably won’t really matter , it will be dependent on the pump how much flow you have. Only down side would be the cost of the 1” vs 3/4”.
10-14-2018, 11:52 PM | #9 | |
10-15-2018, 09:12 AM | #10 |
I’m going to be running the Stewart EMP pump (check out prospeed’s website to check it out) From my knowledge you can’t buy a better pump...
10-15-2018, 03:59 PM | #11 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
EMP is the top of the line, the instruction says to feed the pump with a 1" line so I just did the whole thing 1", but I'm not running to the trunk.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
10-15-2018, 04:01 PM | #12 |
10-15-2018, 04:16 PM | #13 |
Sucker Punch
I'm running a chiller with no HX, I running BMR tank to the EMP pump to the chiller to the supercharger, I had the F manifold on the supercharger modified to accept -16 AN fittings so I could run the 1" to it, also when I ordered the BMR tank I had them weld -16 fittings on it.
10-15-2018, 06:04 PM | #14 | |
Thread Tools | |
