Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 10-03-2019, 11:26 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Rear/front cover alignment tool??
Anyone in the SFV or Santa Clarita area have the tools I can Barrow this weekend?
Or if someone knows a trick to doing it without the tool let me know!
scv_guy is online now   Reply With Quote
Old 10-04-2019, 10:34 AM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Maybe get the sac city kit?
https://www.saccitycorvette.com/AlignItTools.html
747 RWHP 794 RWTQ
Old 10-04-2019, 10:39 AM   #3
scv_guy
scv_guy's Avatar
Originally Posted by hammdo View Post
I'll check it out
Old 10-04-2019, 12:10 PM   #4
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
I've built about a dozen motors without the tool and I'm not sure if it's luck or I'm doing a great job but no leaks thankfully!
I usually snug the bottom that connects the covers to the pan about 12-15 lbs then go around in the proper torque sequence. Don't forget to make sure everything is clean the sealant in the corners/along the oil pan.
Seeing how cheap the tools are now I should prob buy one
GJDM
LsxDoctor is offline   Reply With Quote
Old 10-04-2019, 12:33 PM   #5
scv_guy
scv_guy's Avatar
So you install the Oil pan first, do you use a straight edge to align the pan?
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
