Old 12-30-2011, 01:21 PM   #1
gjarzabek009
gjarzabek009's Avatar
Drives: 1LT
Is it safe to remove paint with a paint thinner/remover...
Painted my bezels but want to go a different route and I need to get the paint off, they won't sand off so I was thinking using a remover/thinner to get the paint off. Would it damage the bezels?
-21" GM wheels -3.73 gears -Injen PowerFlow CAI
-OBX LT headers -Doug Thorley Catback exhaust
-Magnaflow High Flow cats -Trifecta Tune
-VMAX Ported TB
-Maces 25mm Insulator
-Ported Intake manifolds (soon)
gjarzabek009 is offline   Reply With Quote
Old 12-30-2011, 01:25 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I would imagine it may melt the bezels (as the are plastic). You can pick up a brand new set for around $60.
FSP tuned: 377/389
Old 12-30-2011, 01:25 PM   #3
mouse
mouse's Avatar
Drives: 2011 2ss/rs conv, L99/Automatic
If the Bezels are plastic, paint thinner will damage them. if you are just wanting to change their color again, use a "Scotch-Brite " pad to scuff up the surface, and repaint them. no big deal.
mouse is offline   Reply With Quote
Old 12-30-2011, 01:29 PM   #4
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
If they are plastic Lacquer thinner will work but it might damage the chrome finish. Paint remover will definitly damage the plastic, it is very harsh. If they are metal either one would be fine.
I would just scuff and repaint the new color if that's your plan.
HAHA Mouse beat me....
Coop 2010 is offline   Reply With Quote
Old 12-30-2011, 01:32 PM   #5
gjarzabek009
Drives: 1LT
I am going to get them vineled and the guy at the place said I have to remove the paint before they do anything to it. Would scotch-brite get all the paint off?
-VMAX Ported TB
Old 12-30-2011, 01:33 PM   #6
mouse
mouse's Avatar
Yep Mouse beat you "Coop 2010"
Old 12-30-2011, 01:35 PM   #7
mouse
mouse's Avatar
No! it just dulls the surface. preparing for repaint adhesion.
Old 12-30-2011, 01:46 PM   #8
gjarzabek009
Drives: 1LT
so whats the best thing to do if I am going to get them vineled?
-VMAX Ported TB
Old 12-30-2011, 11:12 PM   #9
gjarzabek009
Drives: 1LT
any ideas?
-VMAX Ported TB
Old 12-30-2011, 11:28 PM   #10
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Use the Paint thinner, Paint thinner will effect the Bezel, if the Bezel was soaked in the Thinner, but your just using a rag to wipe off the paint. Just do a little at a time and not soak the rag to much and you should be o.k. I have done the same thing using Acidtone. After you remove the paint from a section wipe it good with a clean towel
gutterball is offline   Reply With Quote
Old 12-31-2011, 12:00 AM   #11
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
soke it in brake fluid and it will come off, used it to take the paint off my bowtie after the paint cracked
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 01-02-2012, 12:53 PM   #12
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Originally Posted by cugino View Post
no one ever heard of goof off? been using it for years. you can get it on your paint and it is safe. i actually use it to remove overspray when a masker/taper does a bad job. works on any material from plastic, chrome, rubber, metal. i'm surprised i didn't see it come up here. comes in pump spray and liquid. under 10 bucks at home depot, loewes. good luck.
that stuff is awesome, have yet to find something that it wont work on
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 01-02-2012, 01:57 PM   #13
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
What is vineled? Why would paint inhibit the process? Personally I would use the paint thinner to rub the paint off using an old rag. The plastic may be damaged by it but your not going to leave the bezel soaking in 100% acetone overnight. Ive used acetone to remove paint from plastics, its no big deal.
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 09:22 AM
does any know to remove strips without damaging the paint supersnake09 Cosmetics and Lighting Modification Discussions 7 01-28-2011 07:25 AM
How to remove or fix gm touch up paint? 2010 Bumblebee Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 03-19-2010 09:48 PM
Remove paint from headlights... DarkDragon85 4th Generation Camaros 9 02-26-2009 06:10 PM
