Old 05-16-2015, 12:16 PM   #1
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Changing Seats 1LS
Has anyone changed their seats from a 2012+ 1LS? The passenger side has no up/down adjustment and of course neither seat is heated, and the power is only to the recliner not to the forward/backward.
If I buy seats out an RS or 2SS with leather, heated, power recline and power forward/back will I need to add any electrical connections? I've heard that there are simply extra connectors below the seats, and I've heard that it would have to be custom done
So which is it? And if only some functions which are they? (For instance maybe the heater won't work but the power forward/back will?)
Thanks
TommyTheCat is offline   Reply With Quote
Old 05-18-2015, 05:11 PM   #2
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
bump, nobody knows?
Old 05-19-2015, 12:44 PM   #3
chevyss69
Drives: 2011 2ss/rs
I have leather in my camaro, the passenger side seat is just power recliner
chevyss69 is offline   Reply With Quote
Old 05-19-2015, 01:53 PM   #4
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
So are all Camaro passenger seats adjusted at the same height no matter what? I guess I could try to put spacers or something if the studs are long enough because my girlfriends short enough she complains about visibility when in that seat, not that it matters so much but it's still kind of annoying to only have the driver seat adjustable.
Old 05-19-2015, 04:21 PM   #5
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
Depends on model year. My 2015 is power in all positions.
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 05-19-2015, 04:48 PM   #6
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
So 6 way?
Forward, backward, up, down, and recline forward/backward?
Old 05-28-2015, 08:18 PM   #7
ztopdoge8
Drives: 2013 2ls Rally Yellow
Tommy: I have the exact same problem with my 2013, my wife HATES even riding in it because it feels like she is sitting on the damn floorboard. We placed a cushion on the passenger's seat so she could see over the hood and then the AIR BAG would NOT activate. This was also a problem on a Monte Carlo and I did place Spacers under the rear of the seat with longer bolts and it worked just fine. Will be doing the same to my 2013 Camaro. Good luck
ztopdoge8 is offline   Reply With Quote
Old 05-29-2015, 06:43 AM   #8
BluePhoenix
BluePhoenix's Avatar
Drives: 2020 GMC Sierra AT4
I think you would need the seat wiring harnesses from a 2LT/2SS, also you would need a HVAC or Radio unit from a 2LT or 2SS for the heated seat function. Even then both the power pass seat & heated seats may be a programmed function kind of like how the door ABL plugs on 1LT & 2LT models have no power to them. You definitely would need to fully research and make sure it would be worth the money spent into that car.
2023 Camaro 2SS 1LE Summit White
1100 - 3/23/2023
2000 - 3/27/2023
3000 - 3/28/2023
3400 - 4/12/2023 — 4/24 TPW
3800 - 4/28/2023
5000 - 5/30/2023
6000 - 6/03/2023
2020 GMC Sierra AT4 6.2L Black
BluePhoenix is offline   Reply With Quote
