Old 01-30-2013, 01:13 PM   #1
iCamaro
iCamaro's Avatar
Drives: 2012 LT RS Camaro
How to retain RS front badge on new grille
I just ordered a new grille and I want to keep my RS badge on the front drivers side. What is the best way to attach it to this mess grille?
iCamaro is offline   Reply With Quote
Old 01-30-2013, 01:17 PM   #2
iKeablr
iKeablr's Avatar
Drives: Chevrolet Camaro 2011 RS 1LT
3M adhesive I say is the best. That is how I attached my RS badge on my new grille. Still going strong since August.
Camaro 2011 VR 1LT RS - Prometheus Prime
|Leather Interior|Leather Door & Dash Trim|12" Subwoofer|Dash ABL|Plasma DRL|
iKeablr is offline   Reply With Quote
Old 01-30-2013, 01:25 PM   #3
iCamaro
iCamaro's Avatar
That was my first thought too, but didn't know if it would really hold up in the wind and rain while driving.
Old 01-30-2013, 01:36 PM   #4
iKeablr
iKeablr's Avatar
Mine is holding up good. I have been through freezing temperatures, rain, snow, and heavy winds. Has not budged and does not feel like it will.
If I am not mistaken the RS badge is originally on the car with a 3M adhesive only no screws, just like the chevy badge on the rear trunk panel, and the words CAMARO on the sides. You should have no worries.
Old 01-30-2013, 01:38 PM   #5
iCamaro
iCamaro's Avatar
Awesome, did you use the original badge that was on the front of the car?
Old 01-30-2013, 01:41 PM   #6
iKeablr
iKeablr's Avatar
Yes I did. I was looking at prices for a new badge with the adhesive and I wasn't going to just buy a new one, when it only needed an adhesive backing. Just make sure when you apply the badge on a clean surface.
Old 01-30-2013, 01:45 PM   #7
iCamaro
iCamaro's Avatar
Great, one more question. Did you apply yours to mesh like I'm going to? I was thinking I'm going to have to put 3M on the badge attach to the mesh and since it has holes take another strip of adhesive and apply on the other side. Just like sandwiching the mesh between to strips.
Thanks for your help!
Old 01-30-2013, 02:05 PM   #8
Leem12
Leem12's Avatar
Drives: 2012 Chevy Camaro (RS)
How do you get the emblems off?
Once there off u jus stick them back on?
Camaro Cruising
Leem12 is offline   Reply With Quote
Old 01-30-2013, 02:35 PM   #9
iKeablr
iKeablr's Avatar
Ahh, I see if you put it on the mesh you can try to do the method you spoke of, it would hold better than just one side, because you do it to one side the adhesive will sure to get dirt and fall off. I was thinking that you were going to apply it on the thicker chrome bar of the grill. Just make sure when you go with the sandwich method you apply enough pressure to hold them together well, and check the emblem ever so often to see if it will budge. If it budges then you have a problem. Like to see the finished product.
EDIT: @Leem12
What I did to take off the emblem was used a heat gun applied enough heat to make it much easier to pry off the bracket. But if you use a heat gun don't apply too much heat as you can deform the emblem. I did that when removing my rear chevy badge, it got deformed. Had to junk it. And yes once you take them off you can just stick them back on with a new adhesive. Fairly simple if you have the right tools.
Old 01-30-2013, 02:52 PM   #10
iCamaro
iCamaro's Avatar
EDIT: @Leem12
I didn't realized the bracket was only attached to the badge with adhesive. I thought I was going to have to cut and sand. That's good news!
