Old 09-11-2013, 12:53 AM   #1
ryan's camaro
Taeng
ryan's camaro's Avatar
Drives: Fast
Problem Solved?
Hi Camaro5 community,
I've been driving my 2012 Camaro 2LT/RS for quite some time now, since 2011. In that time, I've noticed my steering wheel become more and more leaned to the right when I'm driving straight. The roads here in So Cal are wrecked, uneven pavement, and sometimes potholes and cracks. I've never ran my car up against anything, so I know I couldn't have damaged my suspension. I was wondering if a strut tower brace could make the car stiffer and, perhaps, correct the steering issue as the strut tower brace, as the name states, braces the two front strut towers, keeping the struts fixed in one position at all times.
I'm not sure if this is what will solve my problem, so I ask for any input. Whether it be experts or people that have noticed any benefits, if at all, from installing a strut tower brace to their non-convertible Camaros.
ryan's camaro is offline   Reply With Quote
Old 09-11-2013, 08:05 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Nope...a strut tower brace won't change anything for you. Sounds like you need an alignment and/or new tires.
Build Journal
Old 09-11-2013, 08:49 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I agree, it definitely sounds more like an alignment issue to me. Have you ever had the alignment checked and if so what were the alignment specs?
Old 09-11-2013, 10:38 AM   #4
SPCBA
Drives: pleather and Chiclets
Even the company that sells strut braces said check alignment
SPCBA is offline   Reply With Quote
Old 09-11-2013, 10:31 PM   #5
ryan's camaro
Taeng
Drives: Fast
Alright thanks. I'll go ahead and get that checked out
Old 09-11-2013, 10:36 PM   #6
04GOAT-11SS
Drives: 2011 2SS/RS 2004 GTO
Sounds like the wheel is just off center but if you have a lot of road crown where you normally drive, be sure to mention it to the technician aligning it. This can cause what it sounds like you're describing. Adjustments can be made to the camber or caster settings to correct for this.
2011 2SS/RS - Kooks Headers, HFCs, Corsa exhaust, Magnacharged, Cold Air Inductions CAI, tuned by JRE
04GOAT-11SS is offline   Reply With Quote
Old 09-12-2013, 09:10 AM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Get it checked out and let us know what you find out.
Old 09-12-2013, 12:10 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Definitely an alignment issue IMO
Best regards,
Tyler
888-308-6007
Old 09-12-2013, 01:49 PM   #9
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Are you sure you have the same air pressure in both tires. a front tire can pull not much ifthe air is down. even heard of radial pull.
