Old 03-15-2014, 02:19 PM   #1
sycraft
COTW 5/06/2013
sycraft's Avatar
wideband/ boost all in one
anyone have any experience with this guage.
http://www.veisystems.com/products/d...ir-fuel-ratio/
Old 03-15-2014, 03:07 PM   #2
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Another option is www.dynotunenitrous.com. I bought one of their dual gauges, boost on top and wideband on bottom, then stuck it to the dash with velcro. Nice small square, mostly matches the dash if you get blue background with black letters.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 03-15-2014, 03:33 PM   #3
Bill@RaceProvenMotorsports
Bill@RaceProvenMotorsports's Avatar
Drives: 09 G8 GT
We use the AEM Failsafe Wideband/Boost Gauge
http://www.aemelectronics.com/wideba...safe-gauge-84/
Bill@RaceProvenMotorsports is offline   Reply With Quote
Old 03-15-2014, 05:44 PM   #4
stevieturbo
Drives: it changes
For boost I always prefer a swing needle gauge, just easier to see at a glance.
stevieturbo is offline   Reply With Quote
Old 03-16-2014, 12:15 AM   #5
04GOAT-11SS
Drives: 2011 2SS/RS 2004 GTO
If you have HUD my vote goes for the dashtronix gauge projector. Very stealth. Puts the AFR and boost up on the windshield.
2011 2SS/RS - Kooks Headers, HFCs, Corsa exhaust, Magnacharged, Cold Air Inductions CAI, tuned by JRE
04GOAT-11SS is offline   Reply With Quote
Old 03-19-2014, 09:48 AM   #6
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Does the needle gauge pulse around like the digital gauges do when cruising? or does it hold steady around the average number? Thanks.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-19-2014, 01:06 PM   #7
stevieturbo
Drives: it changes
A properly installed simple mechanical or electronic boost gauge should be smooth.
If it pulses either the gauge is faulty, or you need to damp the signal line to the gauge or map sensor for the gauge.
Old 03-19-2014, 02:10 PM   #8
TornadoSS
WICKDSS
TornadoSS's Avatar
Sorry, I didn't specify which gauge I was asking about, I meant the wide band needle gauge
Old 03-19-2014, 02:46 PM   #9
stevieturbo
Drives: it changes
As much as a swing needle gauge would be nice for AFR's, and Innovate used to sell them.
I doubt they'd pulse anyway, as they'd have to be heavily damped. It probably isnt the best solution due to their slower response.
But as a reference gauge inside the car, I'm sure one would still be quite usable.
But my comment was directed only at a boost gauge. Digital boost gauge LCD's or whatever are crap IMO.
Old 03-19-2014, 05:39 PM   #10
justinj
justinj's Avatar
Drives: 2011 CAMARO 2SS RS
I use the VEI systems and it works great... If you dont care about a needle it will work. Im runing Boost/afr and IAT/fuel pressure.
2007 GMC stock
2011 CAMARO 2SS RS-kooks long tube/flow-master American Thunder full exhaust, duel electric cutouts, Mcleod RXT, ZL1 3.73 kit, PFADT sway bars, Toe rods, Lowering springs, Trailing arms, solid rear cradle bushings, BMR motor mounts, Stage 7 RPM TR6060, Whipple Supercharger, LPE twin fuel pumps, ID850 injectors, Elite Catch Can, VEI Gauges, Blower Cam LS1 277LCB HR-14, Barton Short Throw Shifter. Widen Stock rims with 315s, Lots more. 615rwhp 530 rwtq on mustang dyno
justinj is offline   Reply With Quote
Old 03-19-2014, 11:11 PM   #11
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
check out aeroforce too
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 03-20-2014, 07:59 AM   #12
Kelly@PCMofNC
Drives: 2010 RS/SS
I just came in here to suggest that as well. The aeroforce gives you a ton of parameters by default, and then you can add boost/wideband to it also.
Kelly@PCMofNC is offline   Reply With Quote
Old 03-20-2014, 08:12 AM   #13
jvoisel
Drives: 2010 2SS/RS M6
ADM boost/wideband or the aeroforce gauges!
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-20-2014, 10:56 PM   #14
Frans96ss
Frans96ss's Avatar
Drives: 96SS
AEM failsafe... Record 2.5 hours of data at all times... Best gauge out right now.
Frans96ss is offline   Reply With Quote
