05-03-2016, 07:36 PM | #1 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Door Panel Inserts
Anyone have their door panel inserts covered in vinyl?
I guess its possible to Plasti Dip them but the idea doesn't thrill me. Ive seen them custom painted but don't really want to have my door torn apart to do it and seems a bit pricey from what Ive seen. I would think that someone who knew what they were doing could cover these in vinyl while they are still on the car. Picture is for illustration purposes. I'm talking about the red insert. Looks like these ones are custom painted but I don't want to drop hundreds for a cosmetic upgrade at this point.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
05-03-2016, 09:07 PM | #2 |
They are super easy to take out. I had the cloth on mine, and was able to have both door panels off, cleaned, plasti dipped, and re installed in a few hours.
Last edited by jsquad; 05-03-2016 at 09:08 PM. Reason: Said I had doors, not door panels off. |
05-04-2016, 06:54 AM | #3 |
Drives: 2010 CAMARO 2SS/RS WHITE Join Date: Jan 2011
I had some custom vinyl done at http://www.facebook.com/vengeancegraphix
I didn't take the panels off, I just did a stick & trim.
05-04-2016, 08:13 AM | #4 |
Love that custom vinyl. Looks great!
05-04-2016, 08:20 AM | #5 |
Ed S.
Drives: 2015 1LS V6 6 speed manual Join Date: Nov 2015
I really like this idea! I was thinking when I'm ready I can probably do it myself as well--but in the Phoenix summers the inside of my car will be hotter than actual Hell, so the professional install is probably my better choice.
"This is RED 5--I'm going in!" - Luke Skywalker
05-04-2016, 08:26 AM | #6 |
Banned
Drives: Camaro Join Date: Mar 2013
Pulled ALL the internal gray/silver trim pieces and painted CRT to match exterior color. Very easy.
05-04-2016, 05:01 PM | #7 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
05-05-2016, 01:19 PM | #8 | |
05-05-2016, 07:41 PM | #9 | |
Probably lots of colors to choose from. They should knock it out in about 15 minutes. But if you want to get "fancy" with it, anything is possible.
06-22-2016, 04:46 PM | #10 |
Drives: 2011 ls camaro Join Date: Dec 2014
How do you get that insert out?
06-22-2016, 04:52 PM | #11 | |
Cool look. Only question I have is, as far as vinyl on the inserts, is for those cars with the factory ABL on them, how difficult would it be to put vinyl there without adversely affecting the ABL? |
06-22-2016, 05:01 PM | #12 |
KNGTFALL
A good shop will either use the film like mine where the light shows through and is diffused farther down the panel.
Or they will use knifeless tape, and cut a fine line at the top of your panel in the vinyl |
06-24-2016, 03:18 PM | #13 |
Drives: 2010 SS/RS ABM Join Date: Jul 2010
Another Vengeance Graphix Vinyl Door Panel.
06-24-2016, 05:13 PM | #14 |
KNGTFALL
Looks good!
