08-23-2018, 03:11 PM | #1 |
Drives: 14 Camaro ZL1 coupe Join Date: Jun 2015
Triple disc clutch issue
14 camaro ZL1 416 stroker
835rwh 813 torque monster triple disc clutch,zr1 slave, rebuilt tr-6060 trans,nw 102 tb boosted,ported blower and heads,E85,MGW shifter etc. 2 problems I could use some help with please. I have reverse grinding, and 5th gear lockout at WOT(140mph). When I let off throttle for a moment, it will slide in 5th and go. replaced reverse lockout, put a 2nd monster clutch in, measured twice, no shims needed, and still same problem, and did all the obvious, bled the clutch, replaced fluid all done by a Master Tech at the dealership and originally done at a speed shop. 2nd issue, when accelerating with about 1/4 throttle, the motor hesitates,jerks every time and then goes. Got and paid a different tuner, and original tune by the speed shop was the best. $25,000 later and I cant find anyone to help me with this turd. Any suggestions where I can trailer my car to somewhere like RPM transmissions? I'm losing my mind, and so I appreciate any suggestions or at least a direction in who can help me. Thanks guys! |
09-07-2018, 09:49 AM | #2 |
Z-BEAST
Drives: 2013 JDP ZL-850 Track Spec ZL1, Join Date: Mar 2013
Hope you get some answers, you can call JDP Motorsports and see if they have any suggestions. Jordan may know someone that can help. Good luck bud.
