Old 08-29-2022, 06:38 PM   #1
Moeman
THE Cone Killer
Moeman's Avatar
Drives: 2015 2SS/RS BVM; 2016 Vette Z51
2015 SS. Need rear end parts
My axle housing, or "Pumpkin" if you want to call it that, is shot.
You cannot get that part new anymore from GM. Junkyards and EBay have them, but which 1 do I need?
6.2, Auto trans. 3.27 gears is what I have.
Will the 3.27 housing out of a manual V6 fit? I know the auto will not with its smaller 2.92 ring gear.
Basically need the housing, because I will be changing the gears,
The axle I have is RPO is GW6 and trans is RPO MYC.
Everything I see is RPO code MYB.
Can anybody shed some light here?
ARH Full exhaust w/ HF cats
CAI Cold Air Intake w/ scoop,
Gears 3.73
BMR 1.25 inch lowering springs, Trailing Arms, Toe Links, Cradle and offset Diff Bushings,
Bilstein Struts, front and rear
ZL1 rear Diffuser, Rocker Panels, 1LE Front Splitter
Z28 High Wing Rear Spoiler,
Tuned by DynoSteve
Moeman is offline   Reply With Quote
Old 08-29-2022, 09:03 PM   #2
bottletalk
Drives: 15 Camaro 2SS M6
why dont u just rebuild it?
bottletalk is offline   Reply With Quote
Old 08-29-2022, 10:42 PM   #3
Moeman
THE Cone Killer
Moeman's Avatar
The housing inside is tore up... the guy I had change gears in it last year messed it up, It was installed very poorly.
I need the housing to rebuild it.
Gears 3.73
Tuned by DynoSteve
Old 08-30-2022, 07:37 AM   #4
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Yes the manual V6 (MV5) housing is the same
NOT A 45 is offline   Reply With Quote
Old 09-05-2022, 10:12 AM   #5
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
I just txt’d a friend who has a Chevy SS that he’s trashed some rear diffs in. I asked if any of his cases are usable.
note: this SS is an LS3 6M with a whipple, long tubes and Borla system, forgot which cam, solid drive shaft, built (heavier) rear end (finally!) and leg size axles. It will run real low 10’s, high 9’s on a good night. He blew up 3 or 4 rear ends before he finally took a case and put some heavy guts in it. The whole time the diff is getting built I’m sending him pics of axles telling him to go anead and order them.
“No, I think it will be OK for now!”
First pass with the new better stronger diff he twisted the right axle like a bread wrapper.
ADVMax is offline   Reply With Quote
