Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
![]() Drives: 2019 Grand Sport Join Date: Jan 2014
Z06 replica question
Ok so I purchased a set of 18x9.5 black chrome Z06 replicas and M/T ET drag radials. Heading to the track for the first time last night my dash lit up like a Xmas tree. Lost power steering traction control eta. I'm assuming it was because of the difference in rolling diameter from new rears and my 22's up front. That being said do they make a Z06 replica that would match for the fronts so I can have the same rolling diameter.
Sorry for the long winded question, just had a frustrating night at the track and new nitrous system didn't work on top of it all ![]() ![]() ![]() |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
18x9.5 wheels aren't the problem, I ran those for 2 years. Problem sounds like you went with a much shorter tire in back. I've never done that but I've read you need to pull some fuses then?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
Thanks I know the 18x9.5 aren't the problem, they worked just fine as far as clearance goes. I was curious if they made a Z06 replica to fit the fronts and what tire size I could use in combination to equal same rolling diameter of the rears. I have MT 305 35 18 drag radials. Again I'm running dd 22's. Looking for fronts on track days.
Thanks Tom |
Does nobody on the forum have Z06 replicas on the fronts???
Writer
I ran a setup like that in the past.
18x9.5 +40mm front and back 5mm spacer up front Grinded part of the strut assmbly ![]() ![]() ![]()
PROJECT HEAVY CHEVY
#6 |
Thanks! Did you have to cut the rollerskates off, also Would an 18x8 or 8.5 Z06 replica fit fronts any better ? If so do you know what offset?
Thread Tools | |
