02-15-2019, 02:16 AM | #1 |
Drives: 2014 Camaro 2LT RS w/ NPP Join Date: Dec 2018
V6 auto trans to 3.45 diff 1 piece DSS?
As the title says, I am looking to swap to a 3.45 lsd in my 2014 2LT auto.
Ive been looking through the threads, but havent found any info if the v6 auto trans has the same driveshaft flange as the v8 manual. And is it possible then to use a manual v8 DSS 1 piece driveshaft or are the lengths different? Any technical info or advise is appreciated. |
02-15-2019, 11:37 AM | #2 |
Drives: 2010 Camaro Join Date: Nov 2009
You need the axles, hubs, and rear portion of a V8 or Manual V6 driveshaft to do the swap. You can buy a 1 piece driveshaft but that is pricey. Cheers! |
02-15-2019, 10:32 PM | #3 |
Ok, thanks for the info. Ill post a thread on the build
