10-04-2018, 10:55 PM | #1 |
2011: DIC Digital Speedometer Stopped Working....
Hello all,
I have started having an interesting problem with my 2011 LT. Everything else seems to be working fine in the DIC (Driver Information Center), but just the other day I noticed that the Digital Speedometer has just gone totally blank. Has anybody else run into this issue on 2010 or 2011 and know what the fix may be? The classic Speedo on the left side of the gauge cluster is still working fine and now I'm being forced to use it. lol I find it odd that only the Speedo portion of the DIC would stop working. should I start with disconnecting my battery to attempt to troubleshoot? Any insight anybody has is appreciated. |
10-05-2018, 09:59 AM | #2 |
Drives: 2011 Vistory Red 1LS Join Date: May 2018
Try turning the wheel on the turn signal. There is a spot between displays where the DIC is blank.
The Original Farm Rat
2011 1LS M6 Victory Red Sold 1967 Coupe Green and White 1969 SS 396 Hugger Orange 1969 Z/28 All original White with deluxe interior 1970 RS Blue 1978 Coupe Fugly Green 1978 WS-6 Trans-Am Factory 4 speed 1985 IROC-Z Red |
10-05-2018, 12:00 PM | #3 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Do you have a HUD? If so, does it still display on there? If not, I would try the battery and see if that resets everything.
10-07-2018, 11:55 PM | #4 |
Fixed.......
Thanks for the tip Farm Rat! Never really noticed that blank spot when cycling through on the wheel. That is all it was. I don't cycle through all that often on the DIC, pretty much only to check the oil life monitor. Glad the fix was just me being an idiot, at least that means I didn't have a serious or costly issue.
10-08-2018, 09:16 AM | #5 | |
Thread Tools | |
