Old 04-30-2015, 05:01 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
WOT pulling P1516 & P2101 at hi rpm & wheel spin, going into reduced power mode
I have a condition when going WOT from rolling start in 1st & lots of wheel spin as computer changing gear for me in manual mode that I pop these codes going into reduced mode. It has happen since mods & tune was done but only if I forgot to turn off nannies, so wasn't a big issue as I would turn off nannies & this condition would not appear for the last 18 -24 months until the other day it did it with all nannies off for the first time. I understand that if pedal & throttle body differ more than 7% for more than 0.5 sec these codes appear which I'm guessing is what is happening. Now my question is can this system setting be sorted by a tune adjust to give more error out time or % or should I look at swapping out throttle body & pedal?
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 05-12-2015, 06:36 AM   #2
Kiwi_Camaro_2010
Update: replaced throttle body with ac delco replacement off amazon for $120, issue so far has not appeared in same conditions as before, think problem solved!
Old 06-17-2018, 03:23 AM   #3
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Hi Kiwi, has this problem been sorted as I'm having the same problem with my 102mm BBK, I have just ordered a Nick Williams 102 supercharged model to hopefully stop the limp mode an P2101 code.
Cheers Stubbsy
Stubbsy is offline   Reply With Quote
Old 06-17-2018, 03:57 AM   #4
Kiwi_Camaro_2010
Yep, my problem disappeared with new throttle body, was tempted to go with BBK but saw too many issues online with them & the nick williams was also having issues with s/c etc so just stuck with stock replacement but that was a few years ago, might b sorted now.
Old 06-18-2018, 04:17 PM   #5
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Thanks mate, Nick Williams now makes a supercharged model with a stronger throttle motor, I tried replacing the accel pedal and it made no difference so hopefully the NW 102 will sort it.
