Old 09-09-2013, 01:29 PM   #1
Evan@D3PE
Evan@D3PE's Avatar
Drives: ISF
D3PE Atmospheric Catch Can System!
We at D3 Performance Engineering have always put emphasis on function AND form in everything we do! That being said we recently developed our own catch can system that we believe to deliver the best of both by using high quality components, larger -10 valve cover vents, and building each by hand in house! Made in USA! Recommended for all ZL1 owners and a must for those pushing higher power levels than stock!
Strategically vented to prevent as much odor from entering the cabin as possible (Review from customer here http://www.camaro5.com/forums/showpo...0&postcount=19 )
Constructed with precision cut aluminum, high quality fittings, braided nylon hose, and tig welded in house!
Why is a catch can important?? Photos below of ZL1 with less than 1k miles since this was last cleaned
System will be offered both as a DIY where you can have the supplied fittings to your valve covers as well available in a complete bolt on system with welded valve covers provided and an options core charge based on sending your stock valve covers back.
Should have these available on the web store in the next few days!
http://www.camaro5.com/forums/showthread.php?t=317312
Evan@D3PerformanceEngineering.com
Evan@D3PE is offline   Reply With Quote
Old 09-09-2013, 02:11 PM   #2
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
The system looks great Especially with your coolant reservoir tank. Both are on my next mod list.
2018 ZL1 A10: 749rwhp & 743rwtq
Build post:
https://www.camaro6.com/forums/showthread.php?t=543295
2018 2500HD Duramax: S&B CAI
TripleBlkZL1 is offline   Reply With Quote
Old 09-09-2013, 05:30 PM   #3
Nasdaq
Drives: 2013 ZL1
Agreed...looks awesome good work!
Nasdaq is offline   Reply With Quote
Old 09-17-2013, 09:39 AM   #4
Evan@D3PE
Evan@D3PE's Avatar
Drives: ISF
Got a batch assembled and about ready to ship!
Old 09-17-2013, 01:02 PM   #5
ZL1Reaper
ZL1Reaper's Avatar
Drives: '13 Silver Ice Metallic ZL1
Evan,
I haven't heard of these systems before.
I see the lines connect to the top of the valve covers.
This catch can is not the same as the ones sold by RX or Moroso, for example, that connect on the bottom part of the engine. Would the D3 Can replace those or used in conjunction?
Thanks.
Cass
ZL1Reaper is offline   Reply With Quote
Old 09-17-2013, 02:59 PM   #6
Drew P
Drew P's Avatar
Drives: Camaro ZL1
It replaces it. The D3PE can connects to the same place as all others on the market AND to the valve covers.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 09-17-2013, 07:06 PM   #7
ZL1Reaper
ZL1Reaper's Avatar
By the pictures, there are 3 lines. Two from the valve covers and another I assume from the bottom part. Do you plug the bottom engine inlet that will not be connected to anything?
Old 09-18-2013, 09:38 AM   #8
Evan@D3PE
Evan@D3PE's Avatar
Drives: ISF
Our system uses the oem valley breather location and diameter, we supply a hose that slips over the fitting. The port on the IM that used to go to it gets plugged. As for the breather lines on the oem valve covers, the fittings get removed and the ports get opened to 5/8 and -10 AN male fittings get welded on. We supply the AN hoses that connect from the can to these, the port on the intake pipe is capped. Our system totally removes the pcv system from the intake, allowing nothing but fresh air to be brought into the engine. No contaminated air charge, no oil or oil residue.
Old 09-18-2013, 11:27 AM   #9
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
The products this company makes look like quality products. They appear to be ZL1 specific and will not work for other applications. I have a Whipple on an SS and would like an intercooler tank like they make to replace the plastic tank supplied, but it will not work on the SS. I like the catch can but it mounts where the Whipple coolant tank mounts. I think they are missing on an expanded market by not offering variations to these products. Just saying.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 09-18-2013, 11:33 AM   #10
Evan@D3PE
Evan@D3PE's Avatar
Drives: ISF
The only catch to that is we would need one of every different application to make the different systems requested and be accurate and it would be hard to keep the cost down on something like that which there might not be a demand in higher quantities. If anyone in the Houston area has something different and would like something made we could absolutely do it and save the drawings/dimensions for future use but we don't really do the in and out day to day builds as much as just production fabrication and engine management/tuning so we don't always have the opportunity for every scenario.
Old 09-18-2013, 02:29 PM   #11
ZL1Reaper
ZL1Reaper's Avatar
Cool. Thanks for the explanation.
Old 09-18-2013, 04:03 PM   #12
sspddmn
sspddmn's Avatar
Drives: 2013 ZL1 and 1991 Z28
Evan, I still dont see this on your web store. Are these available yet and how much?
In the garage: 2013 ZL1 VIN# 149 // 1991 Camaro Z28 5.7L // 2016 Audi A6 Prestige Supercharged 3.0 V6 // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 09-18-2013, 04:57 PM   #13
Evan@D3PE
Evan@D3PE's Avatar
Drives: ISF
Yes I have these on the shelf!
Pricing and options listed in this sale thread
Old 01-09-2014, 06:28 AM   #14
USMC/ZL1
Drives: 2013 Chevrolet Camaro ZL1 Black m6
Evan, it says link is no longer active , was wondering if the kit was still available with valve covers and if so how much they were running and what the lead time on them was?
USMC/ZL1 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
