Old 03-03-2018, 10:16 PM   #1
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Smile 2 inch Headers 3 inch exhaust
I managed to install a 2 inch set of Dynatech ceramic coated headers, 3 inch high flow cats, and full 3 inch dual tip Magnaflow exhaust system into my 2014 SS. Further to this replaced all underside bracing with custom braces without spacers. The only other issue will be the need to modify the rear housing behind the diff which is not present on the hardtop. Everything works better than expected. Special thanks to JRE and Kris who did all the prework including proper connection for wide band and proper joint modifications making it all bolt right in.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-03-2018, 10:22 PM   #2
Pro-tuned
Pro-tuned's Avatar
Rear section
Old 03-03-2018, 11:48 PM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Looks like you've got the same setup I do. Sounds great, doesn't it?
EDIT: No cats on mine, though.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 03-04-2018, 03:43 AM   #4
Pro-tuned
Pro-tuned's Avatar
Nice! I do have a different setup; 408CI LQ9 2.9 whipple with fore fuel system. Target is 800RWHP and I’m sure I will get there once tuning is completed. My plan is working on reducing boost (currently 15lbs) while retaining power. Need to check my torque numbers but not expecting much change. I am very pleased with the target and sound results. Has a deep rumble but an explosive sound above 3,000RPM. I installed the dual tip I bought the 1LE diffuser fits the SS and worked perfectly. I’ll see if I can post a sound clip as there are not many around. Overall very satisfied!
Nothing quiet about the 3 inch..
Old 03-05-2018, 07:35 AM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Thank you for your business Paul, Looks great.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-05-2018, 08:47 AM   #6
Pro-tuned
Pro-tuned's Avatar
Thanks Ted!
Can’t emphasize enough of the importance of bracing the body on the vert, definetly will move over time. I custom made all the braces without spacers, it now is stronger than factory.
Old 03-05-2018, 09:13 AM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Come on lets hear it !
camguynj is online now   Reply With Quote
Old 03-05-2018, 10:29 AM   #8
Pro-tuned
Pro-tuned's Avatar
I’m working on it but wanna GoPro it!
Old 03-22-2018, 09:17 AM   #9
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Nice upgrade! Looks awesome!
ZEN357 is offline   Reply With Quote
Old 03-22-2018, 05:24 PM   #10
Pro-tuned
Pro-tuned's Avatar
Best thing is I dropped a lb of boost!
