04-05-2018, 12:23 AM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Coilovers or Factory (1LE strut) setup?
I am trying to decide what to change my existing stock setup (Besides BMR Lowering springs) to. I am not looking to spend more then necessary as the vehicle isn't/won't be seeing any track time.
04-05-2018, 11:16 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you won't be going to the track and don't want to spend more than necessary then your stock parts are all you need . If you want an improvement then I would go with either 1LE or Bilstein's B6's - whichever's cheaper; better coil-overs will be even more $.
04-06-2018, 03:13 PM | #3 |
USA-1
Shop around and look for deals! I got my 1LE shock/strut setup for $200 shipped, and they had 19k miles on them.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-15-2018, 10:14 PM | #4 |
Drives: 15 camaro Join Date: Nov 2016
Did lowering your car hurt it's ability to hook?
04-16-2018, 09:06 AM | #5 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Also, how do you like the BMRs? Any track time with them?
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
