Old 03-24-2013, 06:26 AM   #1
NS
Drives: 2010
Meth System
Anybody useing "Devils Own" meth systems? Whats the word on these systems?
NS is offline   Reply With Quote
Old 03-24-2013, 09:27 AM   #2
Unreal
Drives: 2006 Z06
Alky Control>All
Nick
Corvette Z06 -1200ish rwhp
Old 03-24-2013, 09:48 AM   #3
SC2150
Nothing equals Alky control period.
Old 03-24-2013, 09:56 AM   #4
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Friend bought that kit and it didn't last long, If you don't want to spend a lot look at the AEM kit. If moneys not a problem get the Alky Control kit.
Nitroman28 is offline   Reply With Quote
Old 03-24-2013, 10:01 AM   #5
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
Wonder if I should invest in some meth....
GbrilliantQ is offline   Reply With Quote
Old 03-24-2013, 11:35 AM   #6
RRTX-SS
RRTX-SS's Avatar
Drives: 2010 2SS/RS M6
I have alcohol injection systems kit works great and they just released a new in trunk tank that is a pretty clean install......
2010 Camaro 2SS/RS
416 CI M6-LS3 Kenne Bell 3.6, Livernois Dual Fuel Pump Kit w/KB BAP, Futral Motorsports Blower Cam, SW 2"Headers, Zl1 Dual Mode Exhaust, Street Slayer Billet Twin-Disc Clutch,PFADT lowering springs and sway bars, Iforged Classic Wheels, AI Meth Injection, rx dual checkvalve catchcan, Innovators West 8-Rib pulley setup....690RWHP/701RWTQ @ 10 PSI-CALIBRATED BY KARGER @ SNL PERFORMANCE
1995 Camaro Z28 LT1 M6
383 Fully Forged shortblock
RRTX-SS is offline   Reply With Quote
Old 03-24-2013, 11:56 AM   #7
NS
Drives: 2010
yeh i like the look of the alcohol injections system but the alky control system seems like theirs more to it.
Old 03-24-2013, 12:23 PM   #8
RRTX-SS
RRTX-SS's Avatar
I dont have their progressive controller due to instant boost from my kb.... So i cant say much bout their controller, although my buddy has alky kit on his vette and it works flawlessly maybe u can get best of both lol
Old 03-24-2013, 12:38 PM   #9
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Alky Control is the way to go, and if running a PD blower it should be referenced to the MAF, not the MAP.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 04-12-2013, 02:39 PM   #10
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
Maybe this is the right thread to ask this... just trying to increase me knowledge
Can someone explain what these meth kits are to me?
do they reduce engine life?
what are the requirements to get one?
how do they work... etc etc...
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 04-12-2013, 03:34 PM   #11
Camper
Banned
Drives: 10' 2SS LS3 M6
Alky and dont look back
Camper is offline   Reply With Quote
Old 04-12-2013, 04:50 PM   #12
MA2010SS
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-12-2013, 05:04 PM   #13
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
1 - if they stop working then yes. Engine life will be that point
2 - $$$
3 - It's like having race fuel when you floor it but normal gas when just cruising around.
For what it's worth I have had a snow stage3 for about a year with no problems.
AngelSpeedFreak is offline   Reply With Quote
Old 04-12-2013, 05:10 PM   #14
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
There are two simple reasons for using Methanol
1: Much higher octane rating.
2: Can cool the intake charge.
Technically in and of its self there is no reduction in life to any parts.
Although there are rumors of people hurting the coatings on the rotors of PD Blowers. (Which i havn't had a problem with.)
As far as requirements, you can add methanol to just about anything and see some form of gains. (as long as tuning is involved). However it is typically reserved for engines with some form of boost and/or high dynamic cylinder compression ratios.
Hope this helps
Thanks
Mike Haddad
HaddadMotorsports is offline   Reply With Quote
