06-15-2018, 01:57 AM | #1 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
Ridetech or camber plates & lowering springs
I have both setups. Ridetech coil overs and BMR 1.25” lowering springs with JPSS Knockout camber plates(need struts) which would you use?
Cammed and stalled. Sees mostly cruising, fun nowadays, but hoping to hit some HPDE this summer.
06-15-2018, 12:48 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
If you can find them the Bilstiens are a good option.
Orange Krush II
06-17-2018, 11:27 AM | #3 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Ridetechs. Best ride for your cruising. I have had Hotchkis springs and Pedders supercars and these are the best ride hands down. Does great for autocross and roadcourse. They have built in camber plates I leave on race setting so I get 2.5 degrees camber. I have dead nuts even tire wear across tread width other then inside shoulder edge which doesn’t wear. You do have to watch the wheel offset, wheel and front tire size with the ridetechs though.
06-17-2018, 11:30 AM | #4 | |
06-17-2018, 01:13 PM | #5 | |
Street: front 20x10.5 forgestars with 20 offset. With the camber I have to run 285/35 mpss tires max with a 3-5 mm spacer. Tire clears coilover by about 1/8”. If car is lowered it’s risky to run bigger then a 285 tire. My 2.5 camber keeps the 285 away from the fender lip. With the 295 wide mpss tire, and only 1 degree camber I sliced the outer edge of that tire on a big freeway dip. And 1 degree is all I could use as tire hit the coil springs. My race wheels are 19x10.75 with 15 offset, 305/30/19 re 71s and no spacer and no issues . More clearance then the street set Last edited by VR Baron; 06-17-2018 at 01:56 PM. |
06-17-2018, 02:06 PM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Ridetechs. Come with camber plates. If you want to be low and have an offset that my CCW's have, you can always get shorter springs for the front from them. Fixed my issue.
More to come. |
06-17-2018, 08:56 PM | #7 |
BowtieBelle's SS
That’s the issue I’m having with my ridetech current setup. 1LE wheels and tire size and cutting the outside on fender. Can’t camber more. I am around 1.25” ish drop so I need to raise it I think. But the Allen head is stripped(bought used). Since I’m taking off to fix and knew the other setup cleared, I wanted to see what was preferred/best.
Y’all confirmed what I thought.
06-18-2018, 10:00 AM | #8 | |
06-19-2018, 05:20 AM | #9 |
BowtieBelle's SS
Camber plates are already set inward. Maybe I’ll pull the coil overs soon to get that stubborn bolt out.
06-19-2018, 09:07 AM | #10 |
Cool. And With what I have clears with new mpss s4 tires that run wide with that rim protector. Tire only comes close to only spot on the coil itself. I have 1/8” at that point. At very slow speed when wheel is turned in driveway or in a mall parking lot I do get a bit of rubbing do to the angle but that’s it. I could use a 5 mm spacer instead of the 3mm one but don’t want to get to close to wheel lip again.
06-19-2018, 09:59 PM | #11 |
BowtieBelle's SS
How low are you?
06-21-2018, 07:29 PM | #12 |
06-21-2018, 07:39 PM | #13 |
Had my Ridetechs installed today at SoulSpeed in Austin (these guys rock, been using them for many years).
No issues at all, plenty of clearance with the stock 1LE wheels and tire size. Did not have it dropped much, just told them about an inch. Went from 3.5 fingers to 2.5, scientifically measured :P -2.2 camber in the front and -1.6 in the rear.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
06-22-2018, 08:16 AM | #14 | |
BowtieBelle's SS
So at least .25 up all around should be great for me.
