07-03-2018, 07:11 PM | #1 |
Russ
TPMS will not go into set up mode after installed new sensors
Ok I did a search and read more stuff about the TPMS system than I ever needed to know but I couldn't find anything addressing my issue.
I had the TPM sensors replaced and reprogrammed and everything was working fine when I left the shop that did the replacements. About 10 minutes after leaving the shop my tire light came on and when I checked the tire pressures none of them were communicating. I took the car back and the shop reprogrammed the sensors again and within 10 minutes of the shop a repeat of what happened the first time. While driving every once in a while the pressures will register but only for a few minutes and then go out again. I took the car back out to the shop and when they tried to put the sensors into set up on the DIC it will not go into programming mode now. I have tried numerous times and it will just not go into set up mode. I push the set up button and have held it in for over a minute and nothing will put it into set up mode. I thought about disconnecting the battery in an attempt to reset everything but I haven't tried that yet. Is there a fuse in one of the fuse blocks that controls just the TPM system that I can check? Any suggestions would be appreciated!! |
07-04-2018, 04:32 PM | #2 |
376 cubic inches of fun
Wrong sensors installed.
07-19-2018, 04:42 PM | #3 |
I used sensors from NAPA and the shop used the Snapon TPMS Tool and had no issues.
[SIGPIC]
07-23-2018, 07:16 PM | #4 |
Drives: 2010 2LT Victory Red Join Date: Sep 2011
Previous Vehicles
1970 Impala 2D 350/300 1972 Buick GS 350 1967 Pontiac Firebird 326 1969 Chevelle SS 396/375 I really miss this one 1966 Chevelle SS 396/350 1978 Plymouth Fury 440 1982 VW Scirocco ( Got married ) 1987 VW Scirocco 1992 Ford Taurus V6 1996 Dodge Intrepid 2002 Dodge Intrepid 2002 Mercedes ML500 2010 Camaro 2LT |
08-11-2018, 05:47 PM | #5 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Also
The parking brake lever needs to be pulled up to reset the tpms system. Use factory sensors/stems
