09-20-2018, 02:41 PM | #1 |
Drives: 2016 2LT RS Blue Velvet Join Date: Dec 2016
Air-to-water Intercooling?
I wonder if anyone else has considered going for a custom air-to-water intercooler setup for their car. There is potential for better throttle response from shorter charge pipes compared to a front mount kit, slightly more power from reduced pressure drop across the core, and better intake air temperature management, at the cost of slightly more weight and complexity than the normal air-to-air coolers.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake |
09-20-2018, 02:45 PM | #2 |
Drives: 2017 Camaro Join Date: Mar 2018
An air to air is going to be a better setup for a daily or mostly street driven car.
09-20-2018, 03:35 PM | #3 | |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Well if your gonna go custom, may as well go full on custom. Why not add a freon system to cool the water as well, and really cool that charge down!
09-20-2018, 05:24 PM | #4 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
At some point, when I have some time (LOL!), I 'm going to make an intake manifold with a built in air-to water "intercooler" using laminova intercooler cores. I already have the cores, just need time.
09-20-2018, 05:27 PM | #5 |
Sweet. Kinda like what BMW does with their B58 engine?
09-20-2018, 06:39 PM | #6 |
09-20-2018, 09:28 PM | #7 |
Drives: 1964 Lotus 7 with an LTG Join Date: May 2018
Honestly the gains are often only there in 2 forms.
1. If you use ice to get liquid temps below ambient. That often doesn't last long but works for drag racing 2. Reducing length of piping significantly but this is often thought of as a gain on a manual trans. Many autos will have logic to downshift and thus get back into boost faster For my car I'm considering water because of tight space. I don't love the added weight it will incur |
09-21-2018, 07:36 AM | #8 |
Unless you're a full on race car that sees limited street use, a turbo car will do perfectly fine with a air to air. You look at almost any street build and 99.9% use an air to air well over 1000whp. Any benefit from an iced water to air will be gone after a couple of pulls and you are left with the hassle of filling and draining the tank and the weight and complexity of the system. We aren't looking for the last bit of power from these cars, you could turn it up 1psi and have the same effect.
09-21-2018, 08:11 PM | #9 | |
Coopers Camaro
09-22-2018, 09:37 AM | #10 | |
09-22-2018, 11:42 AM | #11 | |
Coopers Camaro
No, its not just your latest statements. Its your collective, miss-informed ramblings in general all across the forums. (You know, the same reason someone calls you out in nearly every post you make) As far as the 2.0T goes... Yes...YES... We are all well aware of your fabulous Honda racing history. Well guess what?? These arn't Hondas. When you buy one of these and start modding it, then by all means come back and make theoretical statements about what will or won't work for these cars. Until then, hop back in your super sweet Honda, and race back over to the v6 section. P.S. You have got to stop giving bad, or just plain wrong dealer level advice. Once again, these arn't Hondas, GM does things differently.
09-22-2018, 06:34 PM | #12 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
09-24-2018, 07:14 AM | #13 |
That has zero to do with using a water to air over an air to air. That's the point I was making but others have to go completely off subject trying to discredit someone because they don't have an educated reply to the actual subject.
09-24-2018, 03:45 PM | #14 |
Drives: Camaro like Join Date: Jun 2017
Dodge uses the AC to chill the water in the Demon intercooler, and every true turbo racer i talk to at my local strip has a water chiller of some sort in their loop. Its a great idea that is getting more and more attention. But, personally, I'd rather see someone get a reliable, safe, water/meth injection kit for the LTG. There's a ton of universal water/meth injection kits, but it's all DIY and tune at your own risk. Let's see someone duplicate the type of system on the BMW M4 GTS...
