Old 01-20-2018, 09:14 PM   #1
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
Rod Mod Diy?
Anyone have a link to a diy or can give instructions?
I'd like to do my own intake since it's winter.
PM or post here
Thanks!
SSjosh is offline   Reply With Quote
Old 01-21-2018, 05:56 AM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Would also like a DIY write up on this
Old 01-21-2018, 11:22 AM   #3
jc615
jc615's Avatar
Drives: Camaro and Sierra
Doubt you get one as few shops would lose business
jc615 is offline   Reply With Quote
Old 01-21-2018, 11:44 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
+1 - I spoke with the GPI crew at 'cfest and was told the rod mod time consuming, aka labor aka where the real money to be made is...plus the research/testing required beforehand to get it right aka intellectual property...that said so much more to do before rod mod benefits really shine thru...
Old 01-21-2018, 08:42 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The rod mod is what it is.
Rods installed in the manifold to help airflow into the runners. We have also found benefits with removing the stands and porting the plenum during engine dyno testing.
The rods are melted into the rear of the manifold. We weld fasteners on the rods, taper them down like a bullet kind of, and install them one at a time. Then the manifold is drilled and they are bolted in place.
I have seen guys diy it.
Don’t miss with th me rod placement, it’s hard to fix if u do lol.
Rhino79 is offline   Reply With Quote
Old 01-21-2018, 08:42 PM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
wouldn't mind reading a diy if there is one, but i feel like that sort of info is definitely going to be hard to get
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-21-2018, 09:11 PM   #7
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
That answered a lot of my questions, thank you!
Old 01-22-2018, 07:00 AM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Drill press and large bit makes short work of the center posts, sharpen the end of the rod for the back and heat it to pierce the intake (don't miss lol). Small machine screw to affix the rod into position in the tb opening area (drilled and tapped) and some epoxy. Its not for the faint of heart to tackle lol
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 01-22-2018, 02:59 PM   #9
xc_SS/RS
not too bad, but the whole 'dont mess up the rod placement' is a little scary lol
2010 2SS/RS
Old 08-18-2018, 05:36 PM   #10
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Old thread but it was Not to hard to do.
my first post after lurking for a year
I did my own yesterday and it took a little while but wow it made a huge difference in the way it pulls at mid and wot. Total cost for materials was under $25.00 and took me about 1.5hr to take off the manifold, mod it and put it back on. I used 1/2" aluminum rods and stainless steel fasteners. I also used an epoxy made for plastic to metal. Each rod is bolted and glued at both ends(one at the back and one on the side of each)
Tarendor is offline   Reply With Quote
Old 12-03-2018, 07:11 PM   #11
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
I completed mine a few days after this post was made. I took two 3/8 or 1/2" rods and ground them down at the back end and tapped them for an m6 nut. Then tapered the front side, drilled 2 .128 holes in each rod then safety wired the rods in the front. 2500 miles so far and they are still tight.
Epoxied both front and rear as well.
Old 12-04-2018, 12:15 AM   #12
Bo White
Bo White's Avatar
It is time consuming. I did mine but granted mine has a metric ton of port work done.
Yeah you can do it but if you mess up.....
Old 12-04-2018, 11:56 AM   #13
xc_SS/RS
Man you cut those runners waaaayyy back lol how's it run like that?
2010 2SS/RS
Old 12-04-2018, 12:14 PM   #14
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
I think I saw yours on the book of faces. Nice work!
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
