07-16-2020, 02:08 PM | #1 |
Rotating Assemblies Up To 468 CID
I was talking to a guy from Texas Speed on the phone about getting a new engine rotating assembly. He told me the biggest I could go to was a 416 CID, without changing anything. Just purchase and put in. I was thinking I saw some other people doing 427 on here too.
My question is, does anyone know what is required of the engine (or anything else) to go to a 468 CID? The guy explained some but I was a little confused. He mentioned re-sleeving I think (not 100% what's involved in that). The options above a 416 seemed to be a wide variety between a 416 and 468. Any input also would be greatly appreciated. |
07-16-2020, 02:59 PM | #2 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
A 416 would be the stock 4.065in bore with a 4.0in crank. I think the 427 would be a 4.1in crank with the cylinders honed to 4.070in. To get to 468 you would for sure have to re-sleeve and stroke it.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
07-16-2020, 03:12 PM | #3 | |
If you scroll down it says they don't recommend boring over 4.080 inch, but leaving them as thick as possible when running boost. I'd like to SC one day. I wonder if changing my rotating assembly would be no benefit to me then or if it's due to issues with integrity to the structure of the block by thinning them out? |
07-16-2020, 03:18 PM | #4 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think the 468 also requires a tall deck block.
07-16-2020, 03:37 PM | #5 |
07-16-2020, 04:21 PM | #6 |
TSP shows the 468 as being for tall deck blocks, so not an LS3 block.
https://www.texas-speed.com/p-1035-t...-assembly.aspx The largest they go on a short deck block is 454 but I think that is still on an iron block. The 438 or 441 are supposed to work with an LS7. The largest they list for the LS3 is a 427/429 ci. |
07-17-2020, 10:01 AM | #7 | |
07-17-2020, 12:43 PM | #8 | |
GPI Sales Consultant
You can get more bore with resleeving, etc. My first question would be what's the application here... ie. why do you want to get to so much displacement?
Got a question about a GPI product? Feel free to shoot me a message! |
07-17-2020, 03:48 PM | #9 | |
07-17-2020, 03:58 PM | #10 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i would stay with the stock displacement for boost and spend the money on a solid forged bottom end instead
Sent from my SM-G975U using Tapatalk
Bone Stock |
07-18-2020, 11:18 AM | #11 |
You think the 10.5 compression will work then? The rotating assembly is the main determining factor for compression, right?
07-18-2020, 09:27 PM | #12 | |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
10.5.1 static compression (SCR) will be fine for boost. Look at what your dynamic compression (DCR) will be. This may help you. https://www.enginebasics.com/Advanced Engine Tuning/Static vs Dynamic.html
More to come. |
07-18-2020, 10:44 PM | #13 | |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
what is usable/reasonable power for the street. it's not far fetched for LS motors can hit 1000HP boosted without big displacement. all BS and jokes aside in a street car 600hp is a chit load of power on the street. |
07-20-2020, 09:54 AM | #14 | |
