01-31-2019, 02:23 PM | #1 |
Drives: '15 Z/28 Join Date: Jun 2016
Need A little Help w/Brake Pad Information
Hi All,
I would like to try (even for one / two events) the OEM ceramic rotors on the track I would like to have backup pads for at least the front. My usual track supply vendor said they have Pagid RSC-1 pads made for ceramics. He ALSO he said his system shows the pads are the same as used on the Corvette ceramics... is this true? This concerns me a bit as it's the first time I've heard it. Could the same pad work in both calipers even if technically, they are not the same part numbers? My supplier has a great rep and is usually dead on with info - but I need to be certain. The pad part number & description is : Pagid U-8091 Racing Pad For Ceramic Rotors - RSC-1 Compound. So... is the info on our cars using the same pad as the Corvette correct? Is the Pagid pad shape part number correct? Can anyone shed light on this? Second part... I would consider the stock pads, but my dealer quoted me $1036 for front pads and $833 for rear pads... so clearly I need to find a better source for stock pad prices as well. (What the Hell is it with some dealers... jeez) Any help sorting this info out would be appreciated. I will eventually convert to iron rotors (I think) but am looking forward to seeing how the ceramics work. --BierGut |
01-31-2019, 02:59 PM | #2 |
Okay... I'll be the first to post to my own thread requesting information...
I spoke to Pagid directly and learned the RSC-1 pad part #s for the Gen5 Z/28 are: U-8091 front and U-4906 rear. They also confirmed that these are the same pads that are used in the Corvette with ceramics. They have three compounds, RSC-1, RSC-2 and RSC-3 increasing in coefficient of friction and of course wear on the rotor. Posting for anyone how might find it helpful. Sorry if this is a known and often repeated piece of information. Cheers! |
01-31-2019, 03:03 PM | #3 |
@MrRaZ28
Your dealer is trying to screw you on price. I found the front OE pads on GMpartsdirect for $559.82. Part # 23284028 $545 on Summit with a wait time,
Rear pads here https://www.ebay.com/itm/Chevrolet-G...-/162695005292 If you are only doing 1-2 events, and you are sure this car has never been tracked just check thickness and if there are any large cracks/chunks. If not, I wouldn't worry about replacing them or having a back up set for just these events. I had 43k miles on mine before the cars first track day, and they held up fine under multiple sessions with me pushing them harder each time. |
01-31-2019, 06:13 PM | #4 | |
Does ANY dealer in today's online world think they are going to gain business by gouging customers? What they DID DO was lose my business for everything else. So short sighted. |
01-31-2019, 07:09 PM | #5 |
Drives: Z28 Join Date: Dec 2016
Check amazon, from time to time they drop the price, think I paid around 300 last time for the fronts.
Otherwise I agree with chevy2, unless you are driving the car 10/10ths you’ll not go through the fronts in a weekend, definitely not the rears. |
01-31-2019, 07:16 PM | #6 |
I’ve not heard of anyone using the pagid’s, would be good to know they fit.
I have used the G loc from justice Pete, search for him, they were great and in the 400’s iirc. |
01-31-2019, 11:40 PM | #7 |
Drives: 2012 BMW 135i Join Date: Nov 2016
GM PARTS XPERTS has been my source for OE pads - always the lowest price that I've found save for used or a sale on amazon (which I've never been lucky enough to catch). Might be close to you too?
02-01-2019, 07:30 AM | #8 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
If you're looking to just swap pads, i'd be cautious of how they treat the rotors...at $1,400/ea you best be educated on what the pad/rotor interaction is
These pads are worth a look too Racing Brake sintered pads https://www.racingbrake.com/category-s/7272.htm As used by fellow forum member who has a track/race only Z/28 (The manufacturer chimes in as well throughout the thread) https://www.camaro5.com/forums/showt...t=racing+brake
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ Last edited by j o n; 02-01-2019 at 07:46 AM. |
02-01-2019, 01:27 PM | #9 |
Drives: 2014 z28 Join Date: Oct 2018
Rock auto has them for 517$
02-01-2019, 01:47 PM | #10 | |
http://www.pagidracing.com/en/produc...amily-rsc.html |
02-03-2019, 09:25 AM | #11 | |
Drives: . Join Date: Jun 2016
The front OEM pads are manufactured by TEXTAR in Germany and supplied exclusively to Brembo. The rear OEM pads are made by Pagid anyway - again branded as Brembo. https://www.camaro5.com/forums/showt...ghlight=textar Personally when the time comes that I need pads (soon!) I'm torn between Pagid or trying the Racing Brake option. -------------------------------------------------------------- edited to add: I was cheeky and tried an email direct to TEXTAR to see if I could get front pads cheaper direct here in Europe. Unfortunately not.... I got the following response: ---------------- Dear Patrick, This part is not offered in the independent aftermarket of Textar. These parts have been exclusively sold to Brembo to be assembled into your car. So what you have are the OEM pads. The only way to get the same pads again is to look for a Chevrolet dealer, who can purchase the pads for you via the OE channel. Sorry that I have no better answer for you. Mit freundlichen Grüßen / Best regards Jonas Niemeyer Product Manager TMD Friction Services GmbH IAM / Product Management Hitdorfer Str. 55, 51371 Leverkusen, Germany ---------------------- Still if you don't ask, you don't get right!?! |
02-03-2019, 11:54 AM | #12 |
Gotta love the straight forward Germans. You know where you stand with them at least.
02-03-2019, 01:48 PM | #13 | |
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
02-03-2019, 02:37 PM | #14 |
Obviously, I've have not used them yet, but I've always been very happy with Pagid pads with all my other track cars. I've also found they last longer and are a bit easier on rotors (iron), however, don't have that initial hard bite of say some of the PFC pads. I don't think I will get more than about 15 days of track out of the ceramics judging by my friends with them on their Z06s, but who knows... maybe I'll be surprised. There is just a part of me that wants to try the ceramics for no other reason than to try them. I'm 98% certain the car will have iron Girodisc rotor for the 2020 track season.
