12-15-2014, 01:35 AM | #1 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Tran swap
Can a 1LE TR6060 fit a Zl1? Can't find a manual, grey, black wheels, ZL1. Even so I have 35k miles on mines and will lose a lot trade in value compared a brand new or low mile replacement. So a tranny swap is the only option I have left. It will come out cheaper if someone trade or sold parts rather than new but even new would be better than payin more for make up for value lost through mileage
Sent from Wayne's Manor
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
12-15-2014, 05:48 AM | #2 |
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv Join Date: Feb 2012
Of course it will cost you more to go from a high mile Z to a new or low mile one. You could change to a M6 for what your auto is worth if they have close to the same miles.
Just a thought, good luck. |
12-15-2014, 12:26 PM | #3 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The 1LE trans is not a direct bolt up to a ZL1. They have different bolt patterns. The ZL1 is a heavier duty transmission and has totally different ratios. You would be best off putting a ZL1 manual on it if you just have to have a manual. I would not make the swap unless you have a lot of other upgrades in the car. You can probably sell your car and by a used ZL1 with a manual for a wash. The auto and manual have different driveshaft lengths, different rear gear ratios.... like I said unless you have a ton of bucks in the car already you don't want to swap the transmission. Buy one that came from the factory as a manual.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
12-15-2014, 02:02 PM | #4 | |
12-15-2014, 07:17 PM | #5 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
Clutch, flex plate, and driveshaft are different
01-01-2015, 09:59 PM | #6 |
Snake Eater
meaning? trade? can't find anything near the mileage or color.
01-01-2015, 10:10 PM | #7 | |
Snake Eater
01-01-2015, 10:17 PM | #8 |
Snake Eater
I really wish someone just wanted to swap to an auto.
01-01-2015, 10:20 PM | #9 |
Snake Eater
Also understand that it will cost me at least 4500 to do this swap and thats understandable if I am able to keep my car rather than trade and swap colors
01-02-2015, 06:28 AM | #10 |
01-02-2015, 09:49 AM | #11 |
ZL1 Pilot
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
01-02-2015, 11:18 AM | #12 | |
Snake Eater
Something is wrong with the link. I keep having error messages. Sent from Wayne's Manor
01-02-2015, 11:23 AM | #13 |
ZL1 Pilot
Hmmm....... works from my computer and my phone. I dunno
01-02-2015, 11:28 AM | #14 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
