09-16-2015, 01:21 PM | #1 |
Drives: 2015 Red Hot ZL1 Join Date: Jul 2015
Outside exhaust tips are dirty and inside are clean?
Hi guys,
My 2 outside exhaust tips on my 2015 zl1 are black after 200 miles and my two inside ones are almost shiny still from the last time I cleaned them. I thought that maybe it was because I was driving in comfort mode so I switched to sport and still no difference, the inside exhaust pipes stayed clean. Is there any way around this? |
09-16-2015, 01:26 PM | #2 |
KaBoom1701
It's the NPP closing off the two inner exhaust tips.
Just pull the NPP fuse and problem solved.
Mods:
09-16-2015, 01:31 PM | #3 |
Drives: 2014 Camaro ZL1 "SIM" M6 650rwhp Join Date: Sep 2015
Not necessarily.... I pulled my F8 fuse and the outside exhaust tips are still consistently dirtier than the inside
I think it's because the most direct exit for the exhaust is still straight out of the outside tips... No expert but seems logical |
09-16-2015, 06:13 PM | #4 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
That is correct!
2015 Z/28 #642 Black Bad Ass
09-16-2015, 07:45 PM | #5 |
09-16-2015, 08:04 PM | #6 | |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Yep, agree....I am constantly wiping out the exhaust tips and also have done the fuse pull. |
09-18-2015, 09:31 AM | #7 |
09-18-2015, 09:57 AM | #8 | |
Slight noise increase but not anything like an aftermarket exhaust system. |
09-18-2015, 10:02 AM | #9 | |
Drives: '13 ZL1, '99 Trans Am Join Date: May 2013
and uh, yeah it's noticeable, in a good way IMO. Don't you think your hi zoot muscle car is a little quiet at 2000 RPM? |
09-18-2015, 10:10 AM | #10 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I use this inside the tips when I wash the car. Pulled the fuse at 13 miles
09-18-2015, 10:32 AM | #11 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I thought that stuff was for the front of the car...
UPSTATE C5 MEMBER
09-18-2015, 03:13 PM | #12 | |
I am going to look into the fuse pull and give it a shot on the days off and see how I like it. |
09-18-2015, 03:29 PM | #13 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
I can almost guarantee you will keep the fuse out. If you still want the ability to close it there are a couple of different products out there that let you control it(open all time/closed all time/function like factory).
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
09-18-2015, 03:42 PM | #14 |
Highly recommend this... Pulled mine as soon as I got her home... These LSA's are supposed to be heard!!!
