JUICEDMOTORSPORTS
Old 02-13-2018, 06:16 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Coilovers do not allow torque to spec, just spin.
After installing the coilovers I cannot get them torqued on bottom bolt in strut tower. They just spin. I can torque the top bolt.
Any tricks?
I was driving after install and all was good. I hit a hole and now I get vibration going over bumps. I know it is the front coilovers. I cannot torque down the retainer nut. It just spins.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 02-13-2018, 07:11 PM   #2
Synner
Drives: cars
Never heard of a lower strut tower bolt. There's the nut on top and the 2 strut to spindle bolts below. What coilover brand/model? Post a pick of the bolt in question.
Old 02-13-2018, 07:32 PM   #3
edog
edog's Avatar
PROJECT 10-15 CAMARO MONOMAX COILOVERS
PART NUMBER: MMX3600
Old 02-13-2018, 08:50 PM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Never heard of these.Is there a slot at the top of the shaft where a Allen wrench fits to keep shaft from spinning aso you can tighten the nut?
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 02-13-2018, 08:55 PM   #5
edog
edog's Avatar
Yes.hmmm. let me look at the top hole.
Old 02-13-2018, 09:20 PM   #6
Synner
Drives: cars
It's has a pic of an allen wrench that "should" fit in the top when the adjuster is removed but no idea with $600 coilovers.
Old 02-13-2018, 10:01 PM   #7
edog
edog's Avatar
900 coilovers. But either way, they are nice. I will look at it.
Old 02-13-2018, 10:12 PM   #8
VR Baron
VR Baron's Avatar
Take off adjuster and it will be there
Old 02-14-2018, 10:40 AM   #9
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
With the weight of the car on the wheels, it will be easier to tighten down the jam nut below the retaining plate nut and well as the retaining plate nut.
