sjm autoprod
Old 02-14-2018, 07:12 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Exclamation Need bushings
Need rear lower control arm bushings. Jegs summit and BMR are all out of stock and will be weeks before they get anymore.
Anyone have any in stock?
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 02-14-2018, 08:39 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
get in touch with dynoSteve or Victor at RDP...they have great service, special forum member pricing, free s/h,,,etc...etc..
https://www.rdpstore.com/
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 124K! - All work by me...
Old 02-15-2018, 02:55 PM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Why replace them?
Old 02-16-2018, 02:33 AM   #4
2010_camaro
Why replace them?
The stock ones are soft. The car is on a 15 now using a modified stock lower control arm
Old 02-16-2018, 11:07 AM   #5
JusticePete
The rear inner bushing is not soft. Replacing it with urethane and a free spinning ferule will reduce the spring rate. Tell me what you are trying to accomplish with your suspension changes and I can tell you if that would be a good or bad thing.
Old 02-18-2018, 02:07 AM   #6
2010_camaro
Drag racing
Old 02-19-2018, 10:44 AM   #7
JusticePete
Do you need more or less squat in the rear?
Weight transfer is good?
RWHP?
Rear Tires?
Old 02-19-2018, 01:16 PM   #8
2010_camaro
3700lb curb weight back is lighter than the front by a few 100lbs, 1000whp car leaves on around 600hp, 295 65 15 Hoosier QT Pro.
Old 02-19-2018, 01:18 PM   #9
JusticePete
Stout.
Does is bounce hard off the bumpstops when you launch using 600, or does she squat and stay done?
Any video from the side of the car at launch?
Old 02-19-2018, 07:23 PM   #10
2010_camaro
No videos. Mainly do things "off the track".
My wear pattern is a little off. My guy that does my alignment says the bushings could be flexing causing the issue. Those and the upper inner bushings are the only stock ones in the car left. I'm changing the upper control arms now but I no one has the lowers in stock
Old 02-19-2018, 08:17 PM   #11
JusticePete
The Z/28 upper outer bushings will increase the stability of the IRS, a good move. The only reason to change out the lower inner is to loosen the arm, allow freer movement like a monoball. Press one out and cut it in half. You will find there is a thin layer of dense rubber over a thick steel fertile with a steel outer jacket. It is a stout bushing.
What issue are you trying to correct?
