Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 08-01-2016, 07:14 PM   #1
wernergmhtp
wernergmhtp's Avatar
Drives: 2014 Camaro 1SS/RS A6
Remove brake backing plates for road course??
Yes it's a technical brake question, but I'm posting here to avoid answers from drag racers.
Has anyone, for use on a road course, removed the brake backing plates ("dust shields") from the front brakes? As an engineer, I understand these things serve various purposes, but I'm thinking they may block a whole lot of radiative heat transfer from leaving the back of the rotor.
Potential problems I see include melting stuff behind the rotor (such as ABS sensor wiring) and/or allowing flaming pieces of brake pad to pierce the rubber brake line.
I'm not interested in a brake duct debate (I have the Z28 brake ducts), just an answer of whether anyone has done this and whether it has helped with brake temperatures and wear.
Thanks in advance!
Chris Werner
Author, "How to Rebuild GM LS-Series Engines"
Contributing Editor, GM High-Tech Performance (1998-2014)
wernergmhtp is offline   Reply With Quote
Old 08-01-2016, 07:15 PM   #2
wernergmhtp
Subscribing to my own thread.
Chris Werner
Old 08-01-2016, 09:23 PM   #3
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I think if you look at the ZL1/1LE/Z28 backing plates for the front they are very small and do not block/cover nearly as much of the back side of the rotor.
I just happened to have my 1LE up on the lift with the wheels off so I went out and snapped a few pics for you.
I also believe that if you order the 6-piston brake upgrade kit from Chevrolet Performance Parts they send this smaller backing plate with because otherwise the standard backing plate would interfere with the caliper.
Nick S is offline   Reply With Quote
Old 08-01-2016, 10:12 PM   #4
wernergmhtp
Wow, thank you... this is NOT what my backing plates look like!!! Looks like it is indeed a 1LE thing. Found this on gmpartsdirect.com, and I guess I need a 20944531 and a 20944532:
5 92199929 SPLASH SHIELD, LEFT
6.2 LITER, W/O SUPERCHARGER, W/O PERFORMANCE PKG
$7.28 $4.15
5 92199930 SPLASH SHIELD, RIGHT
$7.28 $4.15
5 20944531 SPLASH SHIELD, RIGHT
6.2 LITER, W/O SUPERCHARGER, W/PERFORMANCE PKG
$29.70 $16.93
5 20944532 SPLASH SHIELD, LEFT
$29.70 $16.93
5 20944532 BACKING PLATE
CAMARO; W/SUPERCHARGER; LEFT
$29.70 $16.93
5 92199930 BACKING PLATE
CAMARO; W/O SUPERCHARGER; RIGHT
$7.28 $4.15
5 92199929 BACKING PLATE
CAMARO; W/O SUPERCHARGER; LEFT
$7.28 $4.15
5 20944531 BACKING PLATE
CAMARO; W/SUPERCHARGER; RIGHT
$29.70 $16.93
Chris Werner
Old 08-01-2016, 10:35 PM   #5
SPCBA
Drives: pleather and Chiclets
I have been without them for some time. I was led to believe they are to protect those bushings more than anything else.
SPCBA is offline   Reply With Quote
Old 08-01-2016, 10:35 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
How are those held on? I heard the rears are held on by 3 tack welds?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-02-2016, 01:03 AM   #7
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
They are bolted on, between the hub and the spindle
Crash76 is offline   Reply With Quote
Old 08-02-2016, 09:00 AM   #8
hammdo
'It's an experiment'
hammdo's Avatar
Fronts...
Rears are the same as the 2SS
-Don
747 RWHP 794 RWTQ
Old 08-29-2016, 01:11 AM   #9
rock1t
Banned
Drives: 2014 2SS 1LE
while you are there, replace them with these.
never over heat the rotors again.
http://www.jdpmotorsports.com/brands...aro-ss-13430cp
rock1t is offline   Reply With Quote
Old 08-29-2016, 07:43 AM   #10
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
I didn't have to modify my front plates at all going from 4 to 6 piston.
Stormcloak is offline   Reply With Quote
Old 08-29-2016, 10:14 AM   #11
Nick S
Nick S's Avatar
You already had a 1LE which came with the smaller backing plates. The regular SS's came with the larger backing plates.
Old 08-30-2016, 12:27 AM   #12
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
Ah, I mis-read :(
Old 08-30-2016, 10:53 AM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Since I have a set of CTS-V Calipers coming these would a nice addition to make it correct???
Orange Krush II
