Old 06-15-2018, 12:36 PM   #1
captainjy
Drives: 2010 Camaro RS Dark Gray
2010 Camaro RS Bumper popping out on sides
Hi guys, really new to Camaros, loving my recent purchase. I have a few questions and being so new, please forgive the newb questions:
I noticed that the front bumper pops out on each side like the clips or rivets are missing. Are there replacement clips or any suggestions on a good adhesive to hold them?
Side question- anyone know where to get a dark gray rear bumper for my 2010 RS? There's a small puncture on driver side and I'd like to get it replaced.
I'd like to eventually replace the stock engine components with Chevy Orange or some chrome stuff. Any suggestion where to find these?
Appreciate the help!!!!
captainjy is offline   Reply With Quote
Old 06-15-2018, 01:10 PM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
a few pictures would help and clarify about the 'popping' out.
Look in the vendors section here, lots of great vendors with plenty of products.
Old 06-15-2018, 01:26 PM   #3
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
Make sure on that bumper you get Cyber Grey and not Ashen Grey since they changed colors.
Baldman is offline   Reply With Quote
Old 06-15-2018, 01:53 PM   #4
Spec
Drives: 2010 Camaro 1SS LS3
I remember this before I swapped to the ZL1 fascia. It looks like the bottom front end hit the wheel stop, causing the bottom sides of the fascia to bend, and then causing the corners where they meet the side markers to stick out. I tried to see if there was something that could keep it flush.
I didn't look too hard since I was already looking at the ZL1, but I know what you're talking about... and unfortunately not sure how to fix that either. There are no clips holding those corners down.
Adhesive, double sided tape, doesn't quite work because of where they stick out, there's no real contact for those corners to sit on.
Good luck... if you manage to fix it without hitting a body shop, let us know how you did it. I'm sure you're not the only one with this issue.
Spec is offline   Reply With Quote
Old 06-15-2018, 02:04 PM   #5
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
It happened to me Too when I pulled up to far and backed away from a curb. My loco dealership was close by, And I didn’t see how they did it But it was fixed in about 5 minutes. This was 7 years ago and still holding !!!!
Edelbrock EForce Blower, RDP custom grind cam with upgrades,Stainless Power Headers with HighFlow Cats, Stainless Power Retro catback, DSS halfshafts, CAI brand CAI, Tuned ON the Dyno by Steve at RDP. SLP rims,All vinyl stripes removed and painted on, custom hand painted pinstriping, Custom leather seats, Lloyds mats,windows tinted, Sparks emblems, Hurst Billit shifter, and too many small items to list. VDI Scissors doors.
splashlog48 is offline   Reply With Quote
Old 06-16-2018, 12:02 PM   #6
captainjy
Nice guys, thanks for the replies! I'll take a couple of pics here today, too. Appreciate it!
Old 06-16-2018, 01:03 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
I am also dealing with this.
I was in a hurry recently and I ran over my daughter's bicycle...really pissed me off. My own fault for not making sure area was clear, but she has been told a million times not to leave her bike within 1000 feet of my car.
The last pic shows the damage caused when her bike swung up and nailed the side of the fascia. Its bad, but now it gives me a perfect excuse to ZL1 fascia upgrade!
Old 06-18-2018, 12:57 AM   #8
Dusk_2SS
Dusk_2SS's Avatar
Drives: 2013 Dusk Special Edition 2SS/RS
I have some issues too where the bottom of the bumper hangs uneven. Looks there are mounting holes at the back for a trim support, but it's missing if there is such a thing.
Dusk_2SS is offline   Reply With Quote
Old 06-19-2018, 05:43 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
If you are talking about those holes in my picture, yes, those are the holes left from my OEM GFX front splitter.
Old 06-19-2018, 07:06 PM   #10
Dusk_2SS
Dusk_2SS's Avatar
At this point I would remover the whole front bumper, check for anything out of whack, and then place it back on. Most likely will go back in position.
Old 06-19-2018, 08:06 PM   #11
Gordy87
Gordy87's Avatar
Drives: 2010 Camaro SS
Wasnt there a thread related to this, but I believe it was for the rear bumper. Same concept where it was something to do with assembly. Correct me if i'm wrong.
Gordy87 is offline   Reply With Quote
Old 06-19-2018, 09:05 PM   #12
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Seems like screws aren’t in correct place or not there? Somethings off...
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 07-09-2018, 10:36 AM   #13
captainjy
Most of my screws are broken. I think what's happened is the previous 2 owners as well as myself, the front bumper has caught some curbs when backing out and over time it's pulled it loose, breaking the holes. I swear my front bumper seems like it's barely hanging on. If needed, can I replace the wheel wells that have the holes?
Old 07-09-2018, 01:52 PM   #14
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
If this is the problem the OP was referring to, I have had this issue on both of my Camaros after taking the front bumper cover off the first time, What I found is that the small plastic that holds that portion of the cover to the light and body itself is very thin and brittle, what I did was take a small clip style nut, clip it around the plastic that's broken, and then tighten down around that and it will pull the cover to the body tight and snug and keep it there.
The video I'll link below should =show where the nut and bolt is that mounts that section together.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
