08-15-2023, 12:19 PM | #1 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Katech KAT-A7763 Drop-in Dual Fuel Pump Module
Our phase one of our fuel pump is now released for anyone interested. We have 4 of these available right now which can be found in the link below (ignore the backorder).
https://katechengines.com/i-30498248...mp-module.html This fuel pump has the full low level fuel performance of a factory Gen 6 ZL1 fuel pump module with all of the factory connection points. It features twin OEM grade high output fuel pumps that supply near double the amount of fuel as the factory. Currently, this product is meant for the DIY'er, it has the studs to trigger the secondary pump on the top of the module hat. You can use any secondary fuel pump trigger just as you would with an aux pump. We will be releasing a plug-and-play harness that will allow you to control both pumps with commanded fuel pressure via the factory ECU. Also, we will be releasing an inline post-pump filter kit that is serviceable external to the tank. |
08-15-2023, 12:31 PM | #2 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Great solution Zach! Love the plug and play turn key option... any idea when that will be ready?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
08-15-2023, 01:55 PM | #3 |
Petro-sexual
DANG IT!!! I was 6-months too early, lol...
Would it be possible to run this set-up with the factory tune? Let's say I wanted to put this on a STOCK ZL1, with the intent on upgrading in the future. Could I run this with the OEM tune, until I need to bring the second pump on-line? It's a smog-thing (CARB)...
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
08-15-2023, 01:59 PM | #4 | |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
08-15-2023, 06:05 PM | #5 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Hey Mike, output looks to be a LOT less than a Fore Double (and Triple, obviously) that typically run Ti Auto 274/285 pump combos. Can you substitute bigger pumps into your setup like Fore does or are you using smaller pumps to make them fit your bucket?
You should really redo the power levels based on forced induction and E85, since I don’t think you’ll see too many cars on the board making 1200 HP naturally aspirated…
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-15-2023, 06:37 PM | #6 |
Drives: HBM ZLE Join Date: Aug 2017
Can this be used with a jms if already installed?
08-16-2023, 05:38 AM | #7 |
Drives: 2020 SS Camaro A10 Join Date: Jan 2019
Excellent, I want one
08-16-2023, 07:16 AM | #8 |
Petro-sexual
Thanks for the information!
08-16-2023, 07:30 AM | #9 | |
At full steam, this pump flows near double the capacity of the factory ZL1 fuel system without the requirements of -8an/-10an line + a regulator. This fuel system is for the guy that wants up to 1000rwhp on E85 boosted. The pumps we used are much more efficient than the 274/285 fuel pumps above 40psi of fuel pressure. Generally speaking, the pumps used are the equivalent of twin 285's up top. Below is the data from preliminary testing comparing to the factory C7 ZR1 LT5 fuel module. This was done on a mockup flow bench at a 3rd party, but as you can see, the data is different than the OEM level testing. However, it was good for A-B-C testing. If you want near double the amount of fuel from the factory, our solution is the most simple. |
08-16-2023, 07:44 AM | #10 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
How much power roughly would this pump setup support on E60 with a .83-.84 lambda target?
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
08-16-2023, 08:05 AM | #11 |
08-16-2023, 10:22 AM | #12 |
It is hard to calculate from dyno variances between shops, areas, etc. Going by our comparison to the LT5 fuel system, I would take whatever horsepower number you have made on a factory LT4 low-side, and multiply that by ~1.75. I would imagine that would be a close ballpark.
08-16-2023, 11:16 AM | #13 | |
2016 NFG 1SS A8
08-16-2023, 12:31 PM | #14 |
Drives: 2022 Camaro zl1 Join Date: Jun 2023
Awesome stuff! Will this work with a convertible as well? I haven't gotten to deep into it yet but I came across some posts that were some differences between the convertible fuel pumps vs the coups.
