Old 04-06-2021, 03:03 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Steering Wheel Air Bag rattle over bumps
Hey Guys, got a rattle that has been annoying me for a few months now, sounds like its coming from the steering wheel but not sure when going over hard bumps. I disconnected power & removed airbag, if i give it a bit of a shake it has a small rattle, is this normal? Can you pull the airbag holder apart to check internals as don't want to wreck it considering the replacement cost of these things. I have checked all other possibilities around steering column but all seems good there.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
