Old 01-19-2015, 03:00 PM   #1
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Driveshaft length auto vs manual?
Are the driveshafts for the autos longer? I'm putting a ZL1 diff in my SS. Bought a driveshaft from a salvage yard that is supposed to be from a manual ZL1 MG9 code. It's quite a bit longer than my stock one and doesn't properly match up the the transmission flange. I do have the proper flange to do the swap. Only difference in it seems to be the size of the holes. Name:  image.jpg
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 01-19-2015, 03:03 PM   #2
yotaman96
yotaman96's Avatar
2002 Trans Am
Old 01-19-2015, 03:04 PM   #3
Merc
In The Circle
Merc's Avatar
Yes I believe the shaft for the auto is longer then the manual.
Old 01-19-2015, 03:06 PM   #4
yotaman96
yotaman96's Avatar
Thanks. I'm guessing they sent the wrong one. Label attached shows it's the right one. Jeez.
2002 Trans Am
Old 01-19-2015, 03:25 PM   #5
H-E
Drives: 2010 zr1 Camaro 2011 vert
Yes as you see there is a difference,im not sure what they charged you for a stock shaft but we can make a 1pc shaft that fits your SS tranny and the zl1 diff You could get your money back on the factory shaft and skip the issues with the rubber and non serviceable bearing as well as a refund on the yoke. If we can help you out give us a call.
H-E is offline   Reply With Quote
Old 01-19-2015, 03:28 PM   #6
yotaman96
yotaman96's Avatar
Just checked and the new bolts for the ZL1 shaft don't fit the salvage yard shaft. It's probably not even a ZL1 shaft. I'm doing this on a budget. Only paid $200 shipped. If they can't get me the right one, I've found another for about the same price.
2002 Trans Am
Old 01-19-2015, 07:08 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If you have trouble getting a used ZL1 shaft, have you tried to see if a local driveline shop can put the correct yoke on your current shaft to match up to the ZL1 rear? Of course, then you need a ZL1 donut.
I had shafts modified for my 2500HD when I put the ZF6 in and it was around $500 out the door for both including 4 new Spicer u-joints.
Are the bolt holes in the same position on the ZL1 yoke just bigger. If so, can they be drilled and tapped for the larger bolts?
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 01-20-2015, 08:05 AM   #8
H-E
Well hopefully youll get it worked out.They may want more once the figure out what you want.If i can help you out let me know
Old 01-25-2015, 06:17 PM   #9
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Sorry to step in on your post but I have close to the same question. I have a 4l80 with stock SS rear. If I buy the ZL1 3.73 rear will my drive shaft work?
Nitroman28 is offline   Reply With Quote
Old 01-25-2015, 06:59 PM   #10
yotaman96
yotaman96's Avatar
No, it will not.
2002 Trans Am
Old 12-31-2016, 12:23 AM   #11
benjbass
benjbass's Avatar
Drives: 2014 Camaro SS
I need some help and would really appreciate any input. I recently put in a 2013 zl1 differential in my 2014 manual Camaro SS. However, I got it out of an automatic. (though I got the entire thing for 1400 including axles and driveshaft). I did not realize that the driveshaft is longer in the automatics. I am So, I am looking into shortening the drive shaft but I don't know how much I need to tell them to shorten it.
PFA
2014 camaro ss FBO Nitrous Cammed
benjbass is offline   Reply With Quote
Old 12-31-2016, 07:19 AM   #12
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Driveshaft shop will have all the measurements. Better yet just buy a 1 piece from them
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 01-01-2017, 08:20 AM   #13
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Seems odd an auto trans would be SHORTER than a manual but I'm not sure. And I'm in the driveshaft business. Fortunately, we don't sell or see the need for too many replacements on Camaros.
Moto-Mojo is offline   Reply With Quote
Old 01-02-2017, 06:37 AM   #14
jscott
Drives: 2010 2SS RS M6 npp e-force
I have the zl1 6L90 shaft but I heard that the 6L80 is a different length.
jscott is offline   Reply With Quote
