08-04-2017, 12:55 PM | #1 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
What axle on transbrake
Like the title says those with a transbrake what axles are you running? I'm wanting to upgrade before I put it in. Since I'm foot braking right now I'm not to concerned with it snapping the factory ones but once I launch on reverse I know the shock with kill the factory ones on the first or second pass.
08-09-2017, 01:31 AM | #2 |
Will detonate your stock differential it will not take a hit like that was sticky tires. Most people I know of are running a ZL1 Diff with DSS driveshaft and axles. I run DSS 1000 HP axels right now with my M6
08-09-2017, 09:02 AM | #3 |
Svt lol
I have the trutrac in the rear end so it should be able to hold a lot more than that crappy posi system. But if I do grenade the rear end im swapping in a zl1 I want to try and survive as long as I can.
08-10-2017, 03:04 AM | #4 |
Just go with the DSS 1000's . They are stronger than your driveshaft and stock rear with the trutrac.
