10-15-2010, 09:59 AM | #1 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Would I know the difference 93/87 octane
I have never owned a high performance car until now. Would I be able to tell if the dealer put 87 octane in my car. It runs find to me right now, but I was wondering if it would be a noticably difference that you could tell right off the bat. It's not sluggish or anything. Just wondering if the average car guy could tell.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
10-15-2010, 10:13 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
yes.....for the simple reason your was designed to run on 93, thus is will perform better giving it what it was designed for.
10-15-2010, 10:21 AM | #3 |
Booooosted.
BUT, as far as will the 'Average' car guy be able to tell?
Not necessarily. I never knew till I timed mine that it was slow. The 'Butt Dyno' wasn't impressed even after the fuse pull. The 'Feel' was very subtle, and I could have missed it if I wasn't so in tune with my car becasue of the issue. It's not the octane that you would notice anyway. It's what the motor does due to the lower octane. |
10-15-2010, 12:06 PM | #4 |
Drives: 95' Z28, 2010 2ss RS Join Date: Feb 2010
I have read that some guys put 91 or even 87 into their SS's and it knocked.
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback Off road x-pipe Kooks LT Headers |
10-15-2010, 12:48 PM | #5 |
Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
The SS needs at least 91 or the computer goes into the lower performance table. When a gas station attendant accidentally put 7 gallons of 87 on my otherwise full tank of 93, it triggered the need for a fuse pull and I could tell.
My boyfriend don't mind it. |
10-15-2010, 12:50 PM | #6 |
Drives: 2018 Camaro 2SS Join Date: Aug 2010
just to be safe, since you have no idea if the dealer put in premium gas or not, do the fuse pull over night. do it for the piece of mind if nothing else. your car can run just fine on 87, but it will revert to a low octane table and won't be as powerful.
10-15-2010, 01:41 PM | #7 | ||
Booooosted.
10-15-2010, 01:44 PM | #8 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Anything less than 91 is not good. It will knock and feel sluggish
10-15-2010, 01:51 PM | #9 |
Drives: 2018 Zl1 Join Date: Jan 2010
I would say if you had nothing to judge it against you would probably never know the difference. About the only way to tell is if you raced something you should have beat the tar out of or you hit the track.
10-15-2010, 01:56 PM | #10 |
No knock, not sluggish...I think I'm alright. Just wanted to know if they put 87 in I would with out a doubt be able to tell....Thank's for all the resposes
10-15-2010, 02:23 PM | #11 |
Drives: 1968 Firebird & 2011 1LT Camaro Join Date: Sep 2010
Octane has nothing to do with making more power. Octane is an antiknock agent. Engines with higher compression need higher octane to prevent detonation.
10-15-2010, 02:35 PM | #12 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
True, but without the antiknock agent, the car will have to do something else. In the case 87 octane, it pulls timing which does affect performance. A common performance tuning techinque is to advance timing to the point of knock, then backing off. It does give you more power.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
10-15-2010, 02:37 PM | #13 |
Drives: abm2ssrs Join Date: Apr 2009
93. i put in regular once and my car didnt want to move . big differance after fuse pull and full tank of 93
[SIGPIC]
10-15-2010, 02:40 PM | #14 |
NCM-WINR
Drives: 2010 SS/RS IOM 2014 2LT Stingray Join Date: Mar 2009
I did a fuse pull for a guy at our local cruise. He was bitching that his car had no power. I ran into him a few days later and I thought he was going to kiss me he was so damn happy. Yes it seems to be a noticable difference.
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Similar Threads | ||||
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. | radz28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2837 | 07-22-2023 09:07 AM |
Octane Ratings? | Icefsh | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 12 | 03-10-2015 05:10 AM |
How much octane boost can you put in your tank? | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 11 | 05-21-2010 08:41 AM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
Octane makes difference? | ffrcobra_65 | Forced Induction - V8 | 2 | 11-16-2009 01:58 PM |
