JUICEDMOTORSPORTS
Old 01-04-2018, 10:49 PM   #1
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2010 RS
Hood Insert Question...
A couple of months ago, my 2014 ZL1 was vandalized.
One of the scratch victims was the hood insert.
In order to get an acceptable repaint, the insert must be disassembled to remove the water deflector and the 4 vent inserts.
That part isn't really an issue.
The real issue is putting it back together after the repaint.
I have reached out to the actual assembler of the hood insert (TransGlobal LLC) to ask what adhesive was used to bond the Valox type 732E water deflector and the 4 Nylon type 8233G vent inserts to the carbon fiber. (materials were obtained from this link: http://www.plastics.gl/automotive/cool-runnings/ )
To date, I have not received a response.
Would anyone here happen to know what adhesive needs to be used for the reassembly?
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 01-04-2018, 11:03 PM   #2
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
actually a good body shop would tell you that it is a non-serviceable part according to GM and should be replaced.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 01-05-2018, 12:41 AM   #3
VChula
VChula's Avatar
My insurance company will definitely not go for that option.
Besides, I want to change the color of the insert.
Vance Chula -
Old 01-05-2018, 01:03 AM   #4
gmgdave
gmgdave's Avatar
Here is the thing, if it says non-serviceable part they have to replace it. That happened to me with chips due to road debris and it was replaced. No questions.
Old 01-05-2018, 03:41 AM   #5
HDRDTD
It's not clear if the OP has a stock insert or an aftermarket one, plus, he doesn't specifiy if his insert is the exposed carbon fiber one or the painted one.
It sound to be that he has the painted version.
Old 01-05-2018, 11:08 PM   #6
VChula
VChula's Avatar
You are correct, I do have the stock painted insert.
The insert was scratched in only a couple of areas - mostly towards the rear.
Because I want to change the insert color, I want to first disassemble the unit.
The company that originally assembled the inserts has responded to my inquiry about the adhesive and will have an answer to me next week.
Vance Chula -
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
