Old 10-18-2018, 02:32 AM   #1
fofoss016
Drives: ZL1
pushrods size
Hello
what is the right pushrods with BTR TT stage 2 cam 7.400 OR 7.425 ?
with stock lsa heads
fofoss016 is offline   Reply With Quote
Old 10-18-2018, 09:47 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
best thing to do is measure with the $15 tool then order but that cam is on a stock base circle. as long as heads are uncut and using same compressed gasket thickness as stock the 7.400 should be the correct length
ttshovel is offline   Reply With Quote
