05-28-2010, 12:50 PM | #1 |
Drives: 2011 IOM 2SS RS M6 Join Date: Feb 2010
Can I?
I am planning on sprucing up my engine cover.
I going to paint the part of it IBM. But my question is, can put the CF looking vinyl on the sides of it? Will there be any heat issues? Thanks. |
05-28-2010, 01:41 PM | #2 |
Paul
I have seen professionals put CF on the engine covers.
But it does get HOT! SA Chevy and a few others have found this out when they painted theirs.
05-28-2010, 02:11 PM | #3 |
Hmmm, well are you saying that paint gets hot, or the vinyl does?
05-28-2010, 02:31 PM | #4 |
Paul
The engine cover in general gets pretty hot, if you use paint it has to be high temp paint so I imagine same goes with the vinyl. Vinyl will probably hold up better seeing that it can get pretty hot on stripes on a black car in the sun. Some do hydrocarbon and it seems to do well.
05-28-2010, 05:54 PM | #5 |
Well, I think I am going to give it a try.
05-28-2010, 08:56 PM | #6 |
Cavallino
hydrocarbon is a totally different process, more like paint. Chances are the vinyl will not hold up for more than a year maybe two, then it will start to turn.
05-29-2010, 01:52 AM | #7 |
You have nothing to lose by trying. Plus, it can always be peeled off and done again. That's why I do my bowties in vinyl, easily reversible.
I have my engine airbrushed and it's held up perfectly driving through Texas heat.
[B]
05-29-2010, 09:19 AM | #8 |
Ok thank you, I am definitely going to give it a try.
Should I put a clear coat over vinyl? And if so, which one do you reccomend. |
05-29-2010, 01:42 PM | #9 |
Drives: 2SS - Transformer Edition Join Date: Feb 2010
Not true. I painted mine with Krylon Fusion spray paint. It's not high heat (it's made to bond to plastics). I put a Krylon spray on clear coat on top of it. I haven't had any issues with it at all.
There are 542,000 children in foster care. Talk to your local foster and adoptive agency. You could change a life.
05-29-2010, 03:29 PM | #10 | |
Paul
The cover I recently saw with bubble must have been an adhesion issues not a heat one. Thanks for the reminder!
05-30-2010, 12:16 PM | #11 |
What I meant was a clear coat over the vinyl?
