11-20-2015, 10:10 AM | #1 |
GuitarmageddonZL1
Drives: 13 ZL1, 17 TT ZL1, 17 Silverado Join Date: Feb 2015
Upper and Lower Pulley combinations.
What is the biggest lower pulley you can combine with a 2.5 upper, before it starts to get unsafe?
11-20-2015, 10:25 AM | #2 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
11-20-2015, 12:17 PM | #3 |
Drives: '21 ZLE A10 Join Date: May 2012
9.1" lower + 2.55" upper is the max
11-20-2015, 12:19 PM | #4 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2014
8.66 is just below the safe limit which will be 28% overdriving the supercharger wirh the 2.55 upper , the safety limit is 30% . anything more than that is risky .I Dont know if you could go above that with the excuse of a cam/headers (since they drop boost) , will it be safe or not . not sure ...
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
11-20-2015, 12:46 PM | #5 |
GuitarmageddonZL1
I did look at that LSA pulley chart that sometimes floats around the forum. I saw anything above 30% was considered unsafe, but it also says if the engine RPMs are greater than 6500. The LSA redlines at 6200rpm, so you should still be safe, right?
11-20-2015, 02:09 PM | #6 |
Most tuners set the rpm limit to 6500 , so when you tune it will be shifting @ 6500rpm...
11-20-2015, 03:07 PM | #7 |
LSA is way past torque peak at 6500rpm...shift more like 6000-6100 unless you have swapped the cam.
11-20-2015, 05:53 PM | #8 |
GuitarmageddonZL1
Yeah, I figured if the stock tune on an A6 is set up to shift at 5800 in Drive mode and 6000 in Sport mode, then that's probably what's best. I've redlined a few times, shifting at 6200 with the paddles and it's not as good. You can't beat the shifts in Sport mode.
