Old 10-24-2019, 07:11 AM   #1
waylander
Drives: 2013 SS, SLK55, Mercedes GLC, Clio
Small wheels....
just curious here I know the SS came with 20's, but what's the smallest wheel we can run on an SS without modifying anything?
Seems as if we in the UK are getting worse and worse roads so smaller wheels forcheapness and larger sidewalls for comfort is interestin - that being said big, fat tires are going to cost no-matter if a 20" or a 15" (BTW 15 is a joke, even I know they won't fit!!)
waylander is offline   Reply With Quote
Old 10-24-2019, 08:38 AM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
You can run 17" wheels if you tie back the parking brake cable so it doesn't rub.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 10-24-2019, 09:23 AM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
On an SS, you have to worry about the front brakes if you have the rollerskates on them. SOME 18" wheels fit and clear just fine, but that's about as small as you can go with modifying nothing.
2012+ they fixed the parking brake routing, so you shouldn't need do tie back anything to fit smaller wheels in back.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
BMR 1" lowering springs, trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified FULLY 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-24-2019, 04:23 PM   #4
waylander
thanks for that - the question came off the back of a discussion I was having vis-a-vis wheel sizes, UK roads, side-wall etc
Old 10-24-2019, 07:40 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I used my grinder with a cutting wheel and cut the rollerskates off the front, didn't need to remove the pads to do so. Then just let your tire shop know to place the weights on the innermost part of the rim for balancing.. mine fit great with plenty of clearance in the front with 17"s.
In the rear, my 17's fit just fine, I just had to tie back the E-brake cable... but I have noticed a bit of contact with the LCAs...probably happened on hard launches on a well prepped track..
(I have RaceStars)
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
