01-16-2020, 11:48 AM | #1 |
Drives: 2012 Camaro 2SS 2002 Camaro SS Join Date: Dec 2018
NEW LS3 CRATE ENGINE FOR $100
The car has 50k miles and the motor quit. Probably a bad oil pump. Lucky for me the car is under warranty. So for $100, Chevy is installing a new engine. Do you guys think I'm getting another L99 or an ls3? The car was L99. But I thought they discontinued the ls3 l99.
2002 Camaro SS mods (a lot)
2012 Camaro SS mods (a little) |
01-16-2020, 11:51 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
L99. They may not be building new ones but you aren't getting a brand new engine you are getting a remanufactured engine.
01-16-2020, 12:09 PM | #3 |
Started#gottalovethatblue
L99. Greenhornet2 may be right about the remanufactured engine, but if it is under warranty, they're not going to put something close in. They're going to put a direct replacement in. It would be more risk than they're willing to accept to have to reprogram your ECU for the LS3.
01-16-2020, 12:12 PM | #4 |
Do you know what that entails? The block is used, with new internals? Where would the donor engine come? thanks
01-16-2020, 12:16 PM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
It is most likely a GM reman unit.
More to come. |
01-16-2020, 12:20 PM | #6 |
Instagram: Sangstah
It will most definitely be a L99.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-16-2020, 12:37 PM | #7 |
Thanks
01-16-2020, 01:59 PM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
50K miles, huh? Just read somebody’s post the other day of 222K and ‘still going.’ You tend not to think of these things as mechanical crapshoots but I guess they really are. I have 4 months left for the catastrophic failure to occur!
01-16-2020, 02:09 PM | #9 |
All engines that fail under warranty get sent in for cores. they rebuild them and sell them as remans. I don't know what exactly they do. I assume they have a process to resleeve them since usually they only replace engine when there is block damage usually cylinder wall scoring. sometimes lifter bore damage, which I assume they hone or resleeve ect
01-17-2020, 08:19 AM | #10 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Ask for the part number being installed. Can google that part number and see the description or many on here can look it up.
What's the $100 for? Shop lunch? |
01-17-2020, 08:48 AM | #11 |
Deductible, must be a service contract. Which you have to be careful with, some service contracts can get an engine from a junkyard to install.
01-17-2020, 01:26 PM | #12 |
Yes the $100 is for the deductible. The warranty is from Ally which is a subsidiary of GM.
01-17-2020, 01:50 PM | #13 | |
GM Financial is the current financial arm of GM. |
01-17-2020, 07:53 PM | #14 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
if it's a third party warranty it will most likely be a good used motor not rebuilt i deliver them ALL the time to all dealerships.quite a few dealers that thought they were going to get a rebuilt motor and were surprised to see a used motor.but you may get lucky,did they guarantee you a rebuilt or just a replacement? now that being said i haven't had to pick up the used motor because it was bad the transmissions almost always take 2 or 3 before they get a good 1.i have the same warranty as you i will be interested to see what you get.
